RS232 Communication - Netduino Mini - Netduino Forums
RS232 Communication
#1 beerygaz
beerygaz
  • 3 posts
Posted 16 October 2014 - 03:16 PM
I'm new to the Netdunio and am struggling to communicate with it.  I've hacked a serial cable and have wired pins 2-5 to pins 1-4 on the Netdunio.  When I open putty and power up the mini I get the following:
NetduinoMini Build Date: Feb 14 2011 00:59:02
ARM Compiler version 400902
MSdbgV1°ððRïr
ê.NetMF v4.1.2821.0XIP Program found at 0x0010a000
NetduinoMini, Build Date:
   Feb 14 2011 00:59:53
TinyCLR (Build 4.1.2821.0)
Starting...
Created EE.
Started Hardware.     t?ÔÊMSdbgV1qt?ÔÊMSdbgV1wKft?ÔÊMSdbgV1eâ¦t?ÔÊMSdbgV1cPt?ÔÊMSdbgV1i$Kt?ÔÊMSdbgV1oǽt?ÔÊMSdbgV1MvÊ8t?ÊMSdbgV1K<?t?ÔÐÊMSdbgV1A°'7t?ÔÐ
        ÊMSdbgV1GSÑ0t?ÔÐ
     ÊMSdbgV1Uú't?ÔÐ
ÊMSdbgV1Y<ü(t?ÔÊMSdbgV1_ß
                         /t?ÔÊMSdbgV1^xt?ÔÊMSdbgV1t?ÔÊMSdbgV1þwt?ÔÊMSdbgV1pt?ÔÊNo debugger!
Create TS.
 Loading start at 134134, end 1462d4
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Native (4.1.2821.0) (1144 RAM - 6516 ROM - 4479 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) (1752 RAM - 11440 ROM - 7371 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.1.2821.0) (512 RAM - 3488 ROM - 1543 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.IO (4.1.2821.0) (740 RAM - 4620 ROM - 2522 METADATA)
Attaching file.
Assembly: System.IO (4.1.2821.0) (1548 RAM - 13292 ROM - 5862 METADATA)
Attaching file.
Assembly: SecretLabs.NETMF.Hardware (4.1.0.0) (256 RAM - 1108 ROM - 491 METADATA)
Attaching file.
Assembly: SecretLabs.NETMF.Diagnostics (4.1.0.0) (180 RAM - 440 ROM - 166 METADATA)
Attaching deployed file.
Assembly: NetduinoMiniTransportSelector (1.0.0.0) (244 RAM - 1168 ROM - 310 METADATA)
Resolving.
Total: (8788 RAM - 75308 ROM - 41878 METADATA)
Ready.
But I can't seem to send anything, it just sits there.  Is that correct?  I thought I could interact with the device from putty?  I've even added a RS232 diagnostic device and can see activity on pin 2 (When the device boots) but nothing when I try and send anything from the PC.
Am I missing something?
Posted 02 November 2014 - 04:19 PM
Hi beerygaz,
Based on the serial dump, it looks like the Netduino Mini is booting properly.  Since you are using RS232 for transport...is there any chance that your serial adapter is USB-TTL instead of USB-RS232?  Or is using a non-compliant voltage swing?  Or that the PC's TX pin isn't connected securely?
#3 beerygaz
beerygaz
  • 3 posts
Posted 05 November 2014 - 11:47 AM
Definitely not TTL, using a standard USB to RS232 adapter, added a D-Sub connector and broke out RX TX and GND. Tested continuity on all pins. The voltage swing may be an issue, can you give me a pointer as to what it should be and can I spot it with a DMM and no scope?
