How to use Key_RSA
encryption RSA security
#1 tpitman
tpitman
  • 7 posts
Posted 10 August 2014 - 05:16 AM
I have the original Netduino Plus version 1. I am running the stock 4.1 NETMF on it.
I am doing a web server app that I need some security on. I know SSL is not available, so I was thinking I could just use the built in Key_RSA class that comes in 4.1.
The problem is I don't know enough about RSA to get from point A to point B in using it. When I do this:
Key_RSA crypto = new Key_RSA(..., ...);
The ... and ... are byte[] values. The first is called Modulus and the second is called Exponent.
What are those and where do I find them? I read several web pages about RSA encryption and I understand I need a public / private key pair. I did find a web site that talked about the modulus and exponent, but not how you get them.
I found a site that will generate an RSA 1024 bit public / private key pair. They are base 64 strings, but don't say anything about the modulus and exponent parts.
So the question I have is where do I get those values to put into the constructor?
I guess while I am at it I should also make sure that the Key_RSA stuff is actually implemented on the Netduino Plus 1. is it?
Posted 10 August 2014 - 06:25 AM
Hi tpitman,
The old crypto libraries aren't incorporated into the firmware for Netduino.
We did build a managed code AES implementation, if you're interested in playing with that.
Welcome to the Netduino community,
#3 tpitman
tpitman
  • 7 posts
Posted 12 August 2014 - 03:04 AM
Thank you for the welcome. I look forward to doing more with Netduino.
Are you saying that even in 4.1 the RSA stuff is not there?
If that is the case, then yes, I would like to use whatever library you have available as long as it will work in the Netduino Plus 1. I don't have the 2.
Also, what firmware version do I need?
#4 tpitman
tpitman
  • 7 posts
Posted 14 August 2014 - 06:39 AM
bump
#5 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 28 August 2014 - 08:43 AM
Hi
Have a look at this post
http://forums.netdui...ryption-library
https://www.bouncycastle.org/
I have used the XTEA implementation on a Netduino, Fez Spider and Windows Azure projects
Bryn
#6 tpitman
tpitman
  • 7 posts
Posted 28 August 2014 - 09:44 PM
Very nice. Thank you!
Also tagged with one or more of these keywords: encryption, RSA, security
