Hi! I will share working code for this step motor.
Class:
namespace RadugaParnik
public class StepMotorService
private OutputPort _pin0;
private OutputPort _pin1;
private OutputPort _pin2;
private OutputPort _pin3;
public StepMotorService(Cpu.Pin pin0, Cpu.Pin pin1, Cpu.Pin pin2, Cpu.Pin pin3)
_pin0 = new OutputPort(pin0, false);
_pin1 = new OutputPort(pin1, false);
_pin2 = new OutputPort(pin2, false);
_pin3 = new OutputPort(pin3, false);
public void MoveForward(int stepsCount, bool fourSterp=false)
if (fourSterp)
Move4Step(true, stepsCount);
else
Move(true, stepsCount);
public void MoveBackward(int stepsCount,bool fourStep = false)
if (fourStep)
Move4Step(false, stepsCount);
else
Move(false, stepsCount);
private void Move(bool forward, int stepsCount)
int resCount = stepsCount*7;
int step = 0;
bool dir = !forward;
for (int i = 0; i < resCount; i++)
switch (step)
case 0:
_pin0.Write(false);
_pin1.Write(false);
_pin2.Write(false);
_pin3.Write(true);
break;
case 1:
_pin0.Write(false);
_pin1.Write(false);
_pin2.Write(true);
_pin3.Write(true);
break;
case 2:
_pin0.Write(false);
_pin1.Write(false);
_pin2.Write(true);
_pin3.Write(false);
break;
case 3:
_pin0.Write(false);
_pin1.Write(true);
_pin2.Write(true);
_pin3.Write(false);
break;
case 4:
_pin0.Write(false);
_pin1.Write(true);
_pin2.Write(false);
_pin3.Write(false);
break;
case 5:
_pin0.Write(true);
_pin1.Write(true);
_pin2.Write(false);
_pin3.Write(false);
break;
case 6:
_pin0.Write(true);
_pin1.Write(false);
_pin2.Write(false);
_pin3.Write(false);
break;
case 7:
_pin0.Write(true);
_pin1.Write(false);
_pin2.Write(false);
_pin3.Write(true);
break;
default:
_pin0.Write(false);
_pin1.Write(false);
_pin2.Write(false);
_pin3.Write(false);
break;
if (dir)
step++;
else
step--;
if (step > 7)
step = 0;
if (step < 0)
step = 7;
Thread.Sleep(1);
_pin0.Write(false);
_pin1.Write(false);
_pin2.Write(false);
_pin3.Write(false);
Usage:
StepMotorService motorServ = new StepMotorService(Pins.GPIO_PIN_D4,
Pins.GPIO_PIN_D5, Pins.GPIO_PIN_D6, Pins.GPIO_PIN_D7);
motorServ.MoveBackward(2000);
motorServ.MoveForward(5000)
