Netduino plus 1 System Exception
Netduino plus system exception ethernet problem networkinterface
1 reply to this topic
#1 victorSantana09
victorSantana09
  • 10 posts
Posted 09 July 2014 - 01:41 PM
Hello guys!
I'm trying to execute a sample of netduino webserver ,but i'm getting the following
error :  Ocurred one untreated exception of the type 'System.Exception' in Microsoft.SPOT.Net.dll
When i execute the following method : NetworkInterface.GetAllNetworkInterfaces()[0];
I already tried with another code posted here in the forums.
I attached a print of the error and the code . Any ideas of whats happening ?
Thanks in advance! ;)
#2 FredOrJoeBlogs
FredOrJoeBlogs
  • 4 posts
Posted 12 August 2014 - 10:06 PM
I'm not sure of you level of C# experience so I will try and explain this in basic terms, I hope I'm not patronising you.
Your syntax isn't quite right.  On the line where you have:
            //display the IP adress
            NetworkInterface networkInterface = NetworkInterface.GetAllNetworkInterfaces()[0];
The square brackets are in the wrong place, it should be:
            NetworkInterface [] networkInterface = NetworkInterface.GetAllNetworkInterfaces();
This will declare an array of NetworkInterface objects, which will be filled with the result of the function call.
This will make you while loop condition wrong, and everywhere else you use the networkInterface variable, because now networkInterface is now an array rather than a single item.
So this should give you a good start
            while (networkInterface[0].IPAddress.ToString().Equals("0.0.0.0"))
                Debug.Print("Meu IP:" + networkInterface[0].IPAddress.ToString());
                Thread.Sleep(2000);
I have't tested any of this, because I was a cheep skate and didn't get the Ethernet socket, but if there is any problems I'll look at them as soon as I can.
Also tagged with one or more of these keywords: Netduino, plus, system, exception, ethernet, problem, networkinterface
