13.56Mhz RFID module - IOS/IEC 14443 type a
rfid 13.56Mhz
#1 TheMo
TheMo
Posted 17 April 2014 - 05:20 PM
Hi all,
I have a 13.56Mhz rfid module which I want to use with my netduino plus2.
Searched the internet and did not find anything that could get me started.
This module is a mifare reader module. www.seeedstudio.com/wiki/index.php?title=13.56mhz_rfid_module-_ios/iec_14443_type_a
I am new with this and need some help.
Thanks.
#2 jrlyman3
jrlyman3
  • 67 posts
  • LocationNorth St Paul. MN
Posted 18 April 2014 - 02:10 AM
The link you supplied doesn't seem to work.  If your device is: http://www.seeedstud...KHz_RFID_Reader then it looks pretty simple, ground, +5, transmit, and receive.  You would use some code like:
       using System.IO.Ports;
    m_SerialPort = new SerialPort(port, 9600, Parity.None, 8, StopBits.One);
You can find information on SerialPort here: http://netmf.codeplex.com/ or just search on the web.
Have fun.
--John
#3 TheMo
TheMo
Posted 20 April 2014 - 11:50 AM
Hi john,
Thanks for your reply.
I probably pasted it wrong. Hope this link will work.:
http://www.seeedstud...EC_14443_type_a
I already downloaded the .net micro framework.
In your example you open a serial port. Which port do I need to use?
Here is the complete page of the rfid module.
From Wiki ??????
Jump to: navigation, search
Contents
 [hide
Introduction
Model:RFR105A1M
Specification
  • Model No. RDM880-T-A
  • R/W chip MFRC500?MFRC400?MFRC531?MFRC632
  • Standard ISO/IEC 14443 type a
  • Frequency 13.56MHz
  • Baud Rate 9600-115200bit/s?configurable, default9600?
  • Power supply DC5V(5%)
  • Current <70mA
  • Operating range 30-100mm?reading range depend on antenna and card/tag?
  • interface TTL electrical level
  • Working temperature -10 degree to 70 degree
  • Storage temperature -20 degree to 80 degree
  • Size 39*19*9 mm?DIP28?
Resource How to buy
Click here to buy: http://www.seeedstud...pe-a-p-196.html
See Also
Other related products and resources.
Licensing
This documentation is licensed under the Creative Commons Attribution-ShareAlike License 3.0 Source code and libraries are licensed under GPL/LGPL, see source code files for details.
External Links
Links to external webpages which provide more application ideas, documents/datasheet or software libraries.
Connecting to an Arduino
The SeeedStudio 13.56Mhz RFID module is an RFID reader capable support ISO14443A, Mifare series card over a serial line. It can easely be attached to an arduino to have RFID fun.
Schematics
       | [1][2]      [5][4][3][2][1] |
       |  J3              J1         |
       |           RDM880 (top view) |
       |                  J2         |
       |             [5][4][3][2][1] |
J1:(accessory pins)
  PIN 1 -- LEDG (Green led)
  PIN 2 -- 5V (DC)
  PIN 3 -- GND
  PIN 4 -- LEDR (Red led)
  PIN 5 -- BUZ (Buzzer)
J1 Alt: Note that some units are arranged:
  PIN 1 --
  PIN 2 --
  PIN 3 -- LED1 (Green led)
  PIN 4 -- LED2 (RED led)
J2:(Communication using serial 9600 8N1 TTL level)
  PIN 1 -- RESET (pull low to reset e.g. set default baudrate)
  PIN 2 -- RX
  PIN 3 -- TX
  PIN 4 -- GND
  PIN 5 -- 5V (in)
J3:
  PIN 1 -- + Antenna
  PIN 2 -- - Antenna
Use the J2 pin headers to connect 5 volt and the ground as shown in the picture. Connect the TX (Pin 3) to the Arduino digital pin 2 and RX to digital pin 3 as shown bellow. It is not needed to connect the reset as long as you don't change the default connection speed.
Software
[PROTOCOL-821-880_2_.pdf] describes the protocol used for now we only created a small program to read the RDIF tag number when pressing enter in the Serial monitor of the Arduino IDE
Warning: when writing your sketches use only system, Type-A and Mifare commands. ISO14443-B and ISO15693 are accepted only by RDM880-T-E (not 'A') reader! And as of today (21 may, 2012) remember that this module does not support anticollision for Mifare cards -- sometimes it tells there's more than one card, but there's no way to address the non-default card. It's a firmware issue, confirmed by manufacturer.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
char txrxbuffer[255];
char get_readID[] = { 0xAA , 0x00, 0x03, 0x25, 0x26, 0x00, 0x00, 0xBB };
void setup()
Serial.begin(57600);
Serial.println("Hit Enter to read the RFID number");
mySerial.begin(9600);
void loop() // run over and over
int counter = 0;
if (mySerial.available())
  Serial.print(mySerial.read(),HEX);
if (Serial.available()){
    Serial.read();
    Serial.println(">");
    for (counter =0 ; counter < 8 ; counter++){
      mySerial.write(get_readID[counter]);
#4 jrlyman3
jrlyman3
  • 67 posts
Posted 21 April 2014 - 01:31 AM
If you look at the spec sheet http://www.netduino....plus2/specs.htm you'll see
that there are 4 serial ports.  "COM1" ... "COM4".  Since each pin has multiple functions but
can only do one at a time, it all depends on what functions you're using.  I suggest you start
with "COM1" and hook:
    NP2 Pin D0 (RX)  --->  RFID  J2  Pin3 (TX)
    NP2 Pin D1 (TX)  --->  RFID  J2  Pin2 (RX)
    Hook up Gnd and +5 on J1
And you should be ready to go.  You will have to translate the Arduino example to C#.  Here
are couple hints, more information is at http://arduino.cc/en...erence/HomePage :
     Arduino uses the Serial object to talk to the host computer.  Since they only have a single
     serial port (in hardware) they use the SoftwareSerial  class (mySerial) to talk to the device.
     So convert:
         Serial.println  --> Debug.Print
         mySerial.print  -->  m_SerialPort.Write
Of, course they're not one-for-one but we have to leave a little fun for you :) .
Enjoy,
-- John
