Analog Output
5 replies to this topic
#1 Bernie
Bernie
  • 40 posts
Posted 24 March 2014 - 06:36 AM
Is there any kind of built in analog output on the Netduino Plus? I thought there was one, but at the moment don't see on. I need to put out an output value between 0 and what ever is the upper supply rail. It's driving into a high impedance load, so virtually no current is required.
Bernie
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 24 March 2014 - 07:22 AM
All of the outputs on the Netduinos are currently digital (0V or 3.3V).  There are analog inputs but no outputs.
#3 CW2
Posted 24 March 2014 - 07:51 AM
In addition to what Nevyn said, you could use PWM with low-pass RC filter as cheap D/A converter.
#4 mbrossett
mbrossett
  • 46 posts
Posted 26 March 2014 - 01:38 AM
You could also interface with and SPI or I2C DAC device like this one (MCP4821)...
http://ww1.microchip...eDoc/22244B.pdf
Or better yet (if you are looking for cheap and easy)...
http://www.adafruit....CFSISMwodvSgAZQ
#5 mbrossett
mbrossett
  • 46 posts
Posted 26 March 2014 - 01:42 AM
Btw, the MCP48xx family have internal voltage references and the MCP4725 references it's supply voltage. Each has its advantages and disadvantages just depends on what you need the DAC for.
#6 Bernie
Bernie
  • 40 posts
Posted 26 March 2014 - 02:53 AM
Ultimately the analog output will drive an external hydraulic piston. Right now I'm still at the proof of concept phase and the Netduino is the easiest hardware I have around. So I just need to be able to show variable output voltages based on the inputs the program receives.
The other day I ordered parts to build one of these;
http://www.ikalogic....-converter-dac/
I just placed an order with Adafruit, so we'll see which parts get here first, hahaha.
Thanks!
Bernie
