HI all, i am from Bloemfontein South Africa and i study computer engineering here, we use the Netduino Plus 2 in programming and my group is having a bit of trouble with our latest assignment so i hope you guys can help.
The Assignment:
A temperature logging and analysis system using Netduino.
Your Group is to create a TCP/IP based network server application that will run on a Netduino Plus 2.
The server application must allow a minimum of 3 client connections. Once a client is connected the server application transmits the information from several temperature sensors to the client, at a rate that the client specifies. E.g. if the client want the data every 5min the server should only send it once every 5min.
You should also create a client application (that runs on a PC) that is able to connect to the server, receive the temperature data, and save it to a file with a timestamp. Your client should have an option to read the data file and visually display the change in temperature over time in some way or another. The client should also have the means to configure some basic network settings.
The Problem:
We have created bot the server and the client and everything connects like it should the problem we have is that we have no idea how to send and recieve the data from the netduino to the client aplication.
Thanks in advance.
