Is there a convenient way to convert an enum value to a string? I'm accustomed to using .ToString() in the regular framework but it looks like it's returning the numeric counterpart in micro.
Enum to string - is there a convenient way in the MF?
Posted 08 March 2014 - 08:16 PM
Seems like converting between string and enum - both ways - is unsupported in micro framework. I ended up using a hashtable for converting string to enum, this could be used the other way as well. Verbose, but it works.
Posted 03 July 2014 - 04:56 PM
To get the behavior you want, with a little change in the approach, you can use enum.Parse() to convert the action string to an enum value, and switch on that enum value instead. As of .NET 4 you can use Enum.TryParse() and do the error checking and handling upfront, rather than in the switch body.
Edited by Chris Walker, 04 July 2014 - 06:34 PM.
Removed tagline advertisement
Posted 08 July 2014 - 06:57 AM
Elizabeth, did you really try this? I think you didn't, because although this is what the documentation says and how it works in .Net, in my experience it does NOT work like this in .NetMF. That is also the reason this question came up in the first place.
.ToString() gives you the string representation of the integer value of the enum element: I.e. if you have an enum
public enum MyEnum { First, Second, Third }, then MyEnum.First.ToString() will return "0". In .Net, it would be "First".
Same the other way around, .NetMF does NOT parse strings to enum values like .Net - the Enum.Parse() method is not supported.
