Netduino 2 Firmware v4.3.1
30 replies to this topic
#21 Chris Walker
Posted 01 April 2014 - 05:16 PM
dafoink--uninstall the Netduino and NETMF SDKs (which were for VS2012).
Then install the VS2013 versions, here:
http://forums.netdui...o-2013-support/
Does that get you up and running?
#22 dafoink
dafoink
  • 2 posts
Posted 01 April 2014 - 09:31 PM
Excellent!  Works like a charm (well at least a simple blink program.  I will try one of my more complex for my hydroponics this weekend)
Thanks for the help.  Even works on my Surface 2 Pro!
brian
#23 Mous
Mous
Posted 03 August 2014 - 04:35 PM
hello
How to send data to a serial port com?In other word,what is this function that sends  data to a serial port com?
I get data from a counter and a sensor,and i want to send all  the data receive on a serial port.
PS: I use netduino plus 2
Thank you
#24 Ricardo87
Ricardo87
Posted 24 August 2014 - 01:08 PM
Hi all,
I'm unable to install Netduino 4.3.1 SDK.
It will be great to become some advice.
Thanks a lot,
Ricardo
Netduino_SDK_v4.3.1_(February_2014)_20140824145425.log:
[0D78:0AD0][2014-08-24T14:54:41]i301: Applying execute package: NetduinoDrivers_amd64.msi, action: Install, path: C:\ProgramData\Package
Cache\{0BD5725F-7EDB-402A-84C8-544ADE9FFDF5}v4.3.0001\NetduinoDrivers_amd64.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[0D78:0AD0][2014-08-24T14:55:00]e000: Error 0x80070643: Failed to install MSI package.
[0D78:0AD0][2014-08-24T14:55:00]e000: Error 0x80070643: Failed to execute MSI package.
[1680:0978][2014-08-24T14:55:00]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[1680:0978][2014-08-24T14:55:00]i319: Applied execute package: NetduinoDrivers_amd64.msi, result: 0x80070643, restart: None
[1680:0978][2014-08-24T14:55:00]e000: Error 0x80070643: Failed to execute MSI package.
Netduino_SDK_v4.3.1_(February_2014)_20140824145425_1_NetduinoDrivers_amd64.msi.log:
MSI (s) (40:FC) [14:54:59:130]: File: C:\Program Files\Secret Labs\Netduino SDK\Drivers\winusb\x86\winusbcoinstaller2.dll; To be installed; Won't patch; No existing file
MSI (s) (40:FC) [14:54:59:130]: Source for file 'filEA480F37DCE1FC97D519B99826F90A32' is compressed
MSI (s) (40:FC) [14:54:59:239]: Executing op: CacheSizeFlush(,)
MSI (s) (40:FC) [14:54:59:239]: Executing op: ActionStart(Name=MsiRollbackInstall,,)
MSI (s) (40:FC) [14:54:59:286]: Executing op: CustomActionSchedule(Action=MsiRollbackInstall,ActionType=3329,Source=BinaryData,Target=RollbackInstall,CustomActionData=2.12{7B80F291-C93B-4630-857F-D10D81134774}72Netduino DriversSecret Labs LLC)
MSI (s) (40:FC) [14:54:59:302]: Executing op: ActionStart(Name=MsiInstallDrivers,,)
MSI (s) (40:FC) [14:54:59:302]: Executing op: CustomActionSchedule(Action=MsiInstallDrivers,ActionType=3073,Source=BinaryData,Target=InstallDriverPackages,CustomActionData=2.12{7B80F291-C93B-4630-857F-D10D81134774}C:\Program Files\Secret Labs\Netduino SDK\Drivers\mfusb\72Netduino DriversSecret Labs LLC)
MSI (s) (40:CC) [14:54:59:396]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI1DD8.tmp, Entrypoint: InstallDriverPackages
MSI (s) (40:64) [14:54:59:396]: Generating random cookie.
MSI (s) (40:64) [14:54:59:396]: Created Custom Action Server with PID 5824 (0x16C0).
MSI (s) (40:F4) [14:54:59:443]: Running as a service.
MSI (s) (40:1C) [14:54:59:474]: Hello, I'm your 64bit Elevated custom action server.
DIFXAPP: ENTER: InstallDriverPackages()
DIFXAPP: INFO: 'CustomActionData' property 'DIFxApp Version' is '2.1'.
DIFXAPP: INFO: 'CustomActionData' property 'UI Level' is '2'.
DIFXAPP: INFO: 'CustomActionData' property 'componentId' is '{7B80F291-C93B-4630-857F-D10D81134774}'.
DIFXAPP: INFO: 'CustomActionData' property 'componentPath' is 'C:\Program Files\Secret Labs\Netduino SDK\Drivers\mfusb\'.
DIFXAPP: INFO: 'CustomActionData' property 'flags' is 0x7.
DIFXAPP: INFO: 'CustomActionData' property 'installState' is '2'.
DIFXAPP: INFO: 'CustomActionData' property 'ProductName' is 'Netduino Drivers'.
DIFXAPP: INFO: 'CustomActionData' property 'ManufacturerName' is 'Secret Labs LLC'.
DIFXAPP: INFO: user SID of user performing the install is 'S-1-5-21-3214002304-3165699056-822768702-1001'.
DIFXAPP: INFO: opening HKEY_USERS\S-1-5-21-3214002304-3165699056-822768702-1001\Software\Microsoft\Windows\CurrentVersion\DIFxApp\Components\{7B80F291-C93B-4630-857F-D10D81134774} (User's SID: 'S-1-5-21-3214002304-3165699056-822768702-1001') ...
DIFXAPP: INFO: ENTER: DriverPackageInstallW
DIFXAPP: INFO: RETURN: DriverPackageInstallW (0x65B)
DIFXAPP: ERROR: encountered while installing driver package 'C:\Program Files\Secret Labs\Netduino SDK\Drivers\mfusb\MFUSB_Netduino.inf'
DIFXAPP: ERROR: InstallDriverPackages failed with error 0x65B
DIFXAPP: RETURN: InstallDriverPackages() 1627 (0x65B)
CustomAction MsiInstallDrivers returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (40:FC) [14:55:00:036]: Note: 1: 2265 2: 3: -2147287035
MSI (s) (40:FC) [14:55:00:036]: User policy value 'DisableRollback' is 0
MSI (s) (40:FC) [14:55:00:036]: Machine policy value 'DisableRollback' is 0
Action ended 14:55:00: InstallFinalize. Return value 3.
#25 Chris Walker
Posted 14 September 2014 - 06:39 AM
Hi Ricardo,
Are you running the installer with Administrator privileges? Could you please download the installer to your desktop and run it from there?
Also...please try uninstalling any previous versions of the SDK.
#26 Dr Who
Dr Who
  • 261 posts
  • LocationNYC
Posted 14 September 2014 - 04:13 PM
Any plans to convince (or confuse) this release to work with the N1 devices? (Not including the Mini) I'm currently not prepared to obtain an N2 device despite all of the splendidly wild acclaim for the thing in here.
PS See you this coming Weekend at the Faire.
Doctor Who
"This signature does not exist!"
#27 SomeGuy
SomeGuy
  • 10 posts
Posted 15 November 2014 - 04:38 PM
hi !
does this work  for all netduino virsions ,i have a netduino plus, and i also want to clarify about the code in c# because i 've once updated my netduinoPlus to the 4.2 firmeware virsion and I selected the same virsion on the visual c# ide and it starts giving me errors while the code was correct using the previous virsion 4.1(for exemple: "Pins. ..."  doesn't work on 4.2) .So i'm wondering is it the case for this virsion or ...???
#28 bradygaster
bradygaster
  • 15 posts
Posted 06 December 2014 - 08:03 AM
The "Erase App" button is amazingly helpful. Thank you. Best. Thing. Ever.
#29 Chris Walker
Posted 06 December 2014 - 09:21 AM
Dr. Who--we are looking at upgrading Netduino 1 to the upcoming 4.3.2 firmware. 4.3 seems to be a bit too big for Netduino Plus 1 so I don't want to set bad expectations there...but there are a lot of Netduino 1s out there as well and we'd like to give them some love if we can :)
salim's -- the update in this thread is only for Netduino 2. The latest firmware for Netduino Plus 1 is in its sticky post. Regarding Pins. in 4.2...if you're having troubles with that, double-check that you started your project with the Netduino Plus 1 template and that you have SecretLabs.NETMF.Hardware.NetduinoPlus.dll added as a reference to your project.
bradygaster -- thanks for the feedback; I'm glad that the new features are working well for you!
#30 Bryan Bredehoeft
Bryan Bredehoeft
  • 2 posts
Posted 17 December 2014 - 12:48 PM
I have upgraded NP2 to firmware 4.3.1, however if I'm seeing things correctly and remember other posts -- the network stack isn't in the firmware yet.  Any news on when that will be incorporated back in?  Just looking for NTP capability (System.NET, and System.NET.Sockets) to set clock.
Thanks in advance, and hopefully I'm just doing something wrong.
~Bryan.
#31 david98xp
david98xp
  • 57 posts
Posted 19 February 2015 - 06:19 AM
Hey chris. I'm having trouble installing the 4.3 SDK. I'm running 4.3 on my N2. I deleted the old 4.2SDK. I can't install the "WIX" 4.3 sdk.
