Best Answer Fahdil, 23 February 2014 - 10:08 PM
I think, this thread was solved.... as mention by Hanz and andy on the other thread.
I will try it once i got those chips. thanks any way.... love this forum so much.....
Go to the full post  | ||||||||||||||
Extending Digital Input using game Controller
Started by Fahdil, Feb 17 2014 04:39 PM
digital Input game controller
I will try it once i got those chips. thanks any way.... love this forum so much..... Go to the full post
7 replies to this topic
#1Posted 17 February 2014 - 04:39 PM hi guys,
I'm developing a sensor station.... it will have more than 20 digital sensor. so in this case, I will using IC's 4066 to switch a USB Game Controller buttons.
schema:
Digital Sensors ==> 4066 ==> Drive USB Game Controller Buttons ==> Send Byte to PC / Netduino
I've got no problem to do it in windows app. but hopefully to do it on Netduino. is any one have an idea how to send byte from USB to netduino? can I solve this by using USB host shield? or maybe FTDI cable?
appreciate any suggestion.
*additional Note: 4066 is just like a relay, it has 4 block switch on 1 IC. #2Posted 23 February 2014 - 10:36 AM
USB gamepads are typically implemented as HID devices and must be connected to a USB host. The host (usually a PC) periodically polls the device to read the current state of buttons, directional pads, thumbsticks and so on.
I find your project description to be somewhat cryptic - are you looking to have the Netduino act as USB host reading the gamepad or is it the other way around - e.g. the Netduino should act as a gamepad that will be read by a PC over USB as means of sending sensor information to the PC?
#3Posted 23 February 2014 - 11:19 AM Dear hanz,
thanks for your response. Actually I just need to watch 16 and more digital input at the same time. last time I did it in my PC using usb gamepad. This gamepad sent data byte to my PC. (button 1 = byte 1, Button 3 = byte 4, button 4 = byte 8 and so on).
but I dont know how to do it in the Netduino. If there any shield which has 16 button connect to a serial port then it would be solve the problem.
Cheers #4Posted 23 February 2014 - 12:45 PM #5Posted 23 February 2014 - 01:32 PM
Much better, it's a shift register and you can probably use SPI to read it. MISO, CLK and CS pin for latching before reeling in the bits.
...or you could use the MCP23S17 chip, it has 16 pins controlled with SPI. With the driver I wrote for it, you can easily create a 16 bit wide parallell databus and just read them all into a single unsigned short variable:
ushort my16bits = bus.Value;Here's the driver with some examples: http://forums.netdui...17-io-expander/ The driver can also alert you with interrupts whenever any of the 16 pins changes. #6Posted 23 February 2014 - 01:46 PM absolutely cool.....
but... I've using SPI pin to control 16x2LCD display using M74HC595, can I use it together?
thanks anyway... #7Posted 23 February 2014 - 05:38 PM
Thanks, glad you liked it!
Regarding having multiple SPI devices sharing the same SPI bus as the MCP23S17, I eleborated over that in the post that I made over the driver software:
http://forums.netdui...der/#entry56306
Also, I think you need to use the "inhibit" pin or similar on your shift register to sort of turn it off while using the SPI bus for other purposes.
#8Posted 23 February 2014 - 10:08 PM Best Answer I think, this thread was solved.... as mention by Hanz and andy on the other thread.
I will try it once i got those chips. thanks any way.... love this forum so much..... 0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
