Best Answer Chris Walker, 20 February 2014 - 12:51 AM
Hi Uffe, Erase the BIN and OBJ folders for your project (either manually or through the "clean..." option next to Build. Then rebuild your project and redeploy. If that doesn't work, create a new project. Make sure the new empty project deploys alright. Then add in each piece again. If it works after adding everything in, do a file comparison to see what changed in your old project. If it stops working at some point, we can narrow down the issue based on what you've just added into the new project. Chris Go to the full post
