Best Answer wendo, 13 February 2014 - 07:33 PM
COM3 is definitely usable, I've happily run devices on COM3 on my N+2. I assume you're not using pins 7 or 8 for anything else before your serial port declaration?
Go to the full post  | ||||||||||||||
com3 exeception on open port
Started by mjd, Feb 13 2014 02:08 AM
com3 exeception exception HandlePinReservati
COM3 is definitely usable, I've happily run devices on COM3 on my N+2. I assume you're not using pins 7 or 8 for anything else before your serial port declaration? Go to the full post
#1Posted 13 February 2014 - 02:08 AM Hi everyone
i have encountered an exception [font="'courier new', courier, monospace;"]System.IO.Ports.SerialPort::HandlePinReservations[/font] on attempting to open 'COM3' ([font="'courier new', courier, monospace;"]System.IO.Ports.SerialPort::Open()[/font])
i have seen a couple of references to COM3 in the forum but no reports of this problem. i'm using v4.2.2.2 firmware (SolutionReleaseInfo.solutionVersion) which includes assembly: Microsoft.SPOT.Hardware.SerialPort 4.2.0.0.
is COM3 usable? the other comments refer to uart allocation for it and the libraries support its enumeration 'Serial.COM3'.
thanks in advance for any comments
mike #2Posted 13 February 2014 - 03:22 AM What hardware are you using? An N1 doesn't have a COM3 which would explain it if you're trying to do this on an N1.
The N2 obviously does so it should work there #3Posted 13 February 2014 - 03:25 AM Hi Wendo
thank you for the reply.
im using a netduino plus 2
mike #5Posted 13 February 2014 - 07:42 PM great that's it! thank you very much. 0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
