Best Answer Chris Walker, 01 January 2014 - 07:33 AM
Hi Pyt, The internal buffer size is just the size used to transfer serial data close to the hardware level. You should be able to send as much data as you'd like. Chris Go to the full post
Size of uart buffers
Started by Pyt, Dec 30 2013 04:37 PM
Best Answer Chris Walker, 01 January 2014 - 07:33 AM Hi Pyt, The internal buffer size is just the size used to transfer serial data close to the hardware level. You should be able to send as much data as you'd like. Chris Go to the full post
1 reply to this topic
#1Posted 30 December 2013 - 04:37 PM What are the sizes of the UART buffers on the Netduino Plus 2 ? After a little search and experimenting, I figured the receive buffer is 512 bytes and the send buffer 256 bytes. Is this right ? Is this documented anywhere ? Will the SerialPort.Write() method properly work if used with a buffer larger than the size of the send buffer ?
Thanks, Pyt. #2Posted 01 January 2014 - 07:33 AM Best Answer
Hi Pyt,
0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
