Connecting an analog joystick to a netduino
6 replies to this topic
#1 Fabien Royer
Fabien Royer
  • 406 posts
  • LocationRedmond, WA
Posted 09 January 2011 - 09:19 AM
The netduino project that I'm working on requires an analog joystick and I wrote a driver for it, which I hope the community finds useful (these things are deceptively tricky!):
http://fabienroyer.w...-to-a-netduino/
Cheers,
-Fabien.
#2 Jan Olof
Jan Olof
  • 41 posts
  • LocationSweden
Posted 09 January 2011 - 10:29 AM
Fabien, You say that the 5V rail would work too, but is not the max voltage on the analog inputs 3.3 V ? /Jan Olof
#3 bill.french
bill.french
  • 260 posts
  • LocationPrinceton, NJ
Posted 09 January 2011 - 01:25 PM
Did you make the joystick part of a voltage divider circuit, or wire it straight up to the analog input?
#4 Fabien Royer
Fabien Royer
  • 406 posts
Posted 09 January 2011 - 07:10 PM
Fabien,
/Jan Olof
Yup. I should have indicated that a voltage divider would be required in that case. Good catch! I'll fix that.
Cheers,
-Fabien.
#5 Fabien Royer
Fabien Royer
  • 406 posts
Posted 09 January 2011 - 07:12 PM
I used a straight connection to the analog pins in this case as I was using the v3.3 power rail. So, no need for a voltage divider :)
#6 rchelicopter
rchelicopter
  • 18 posts
  • LocationSan Diego, Ca
Posted 08 December 2012 - 08:41 PM
Hello Fabien, I know this is an old post but I just stumbled upon it. I've downloaded your source for the Analog Joystick test but I'm kind of a newb when it comes to C#. What I dont understand is how to use the class, is it possable that you could give me a small example of how to use AnalogInput Xinput and AnalogInput Yinput in a project?
#7 carb
carb
  • 352 posts
Posted 08 December 2012 - 10:08 PM
Hello Fabien,
In case Fabien doesn't see this you can look at a sample that he wrote on CodePlex.com for joysticks. Analog Joystick Sample
Chuck
