I finally was able to write my first program. After a bunch of updates and loading, I was able to write "blink" (even used the onboard button to select a flash rate, so having fun with this!!)
But, I am getting warnings when loading the program to the netduino.
Here is the steps I followed. First off, using a Netduino (not a 2) on firmware 4.1. Would like to upgrade, but I can address that later (feel free to direct me to the thread that instructs how to do this). Using VS 2012 pro. Wrote the code and made all the necessary "property" adjustments to get the code to load.
When I clicked start, the files loaded, the led started to flash, but I got 4 warnings. I hope you can help. Here they are:
Warning 1 Could not resolve this reference. Could not locate the assembly "Microsoft.SPOT.Hardware.PWM". Check to make sure the assembly exists on disk. If this reference is required by your code, you may get compilation errors. Blink
Warning 2 Could not resolve this reference. Could not locate the assembly "Microsoft.SPOT.Hardware.PWM". Check to make sure the assembly exists on disk. If this reference is required by your code, you may get compilation errors. Blink
Warning 3 Could not resolve this reference. Could not locate the assembly "Microsoft.SPOT.Hardware.PWM". Check to make sure the assembly exists on disk. If this reference is required by your code, you may get compilation errors. Blink
Warning 4 The referenced component 'Microsoft.SPOT.Hardware.PWM' could not be found. Blink
Is this normal or have I missed something?
