Threading with ResetEvent and SerialPort problem
Thread Threading SerialPort AutoResetEvent ManualResetEvent WaitHandle
#1 Hachi'
Hachi'
  • 10 posts
  • LocationEurope
Posted 04 November 2013 - 08:20 PM
Hello, I'm interfacing a device via SerialPort. The device will send a response immediately after sending some bytes to the device. Therefore I want a SPI-style WriteRead-Method, which sends some bytes, reading and returning the response-bytes. I'm trying to achive this with the AutoResetEvent class and the DataReceived event. The WriteRead-Method sends some bytes to the device, blocks the call until receiving a response, using AutoResetEvent.WaitOne and AutoResetEvent.Set.
public Byte[] WriteRead(Byte[] bytesToSend){    this.FrameReceived += Device_FrameReceived;    this.Write(bytesToSend); // Send bytes to the device    Boolean signaled = this.autoResetEvent.WaitOne(); // Wait for response (FrameReceived event)    this.FrameReceived -= Device_FrameReceived;    if (signaled)    {        return this.incomingBytes;    }    else    {        return null;    }}
After receiving the bytes, AutoResetEvent.Set is called, to unblock the WriteRead-Method.
private void Device_FrameReceived(Object sender, FrameReceivedEventAgs e){     this.incomingBytes = e.Frame;     this.autoResetEvent.Set();}
The code above works if it's executed before Thread.Sleep is called in the Main-Method. If the code is executed after Thread.Sleep, the code doesn't work. Device_FrameReceived is never called.
public static void Main(){    device = new Device();    device.FrameReceived += device_FrameReceived;     // This will work, because Thread.Sleep isn't called    // Byte[] bytes = device.WriteRead(bytesToSend);    Thread.Sleep(Timeout.Infinite);}private static void device_FrameReceived(Object sender, FrameReceivedEventAgs e){    // This won't work, beacause Thread.Sleep is already called    Byte[] bytes = device.WriteRead(bytesToSend);}
I attached a sample application which demonstrates the problem, maybe someone is willing to explain me the problem and how to solve it.
#2 perpetualKid
perpetualKid
  • 20 posts
Posted 04 November 2013 - 09:45 PM
your code looks correct, I would have implemented it in a similar way.
However I feel that Thread.Sleep(Timeout.Infinite) on the main thread just renders my devices unusable, both in a way that interrupt handler and other code not executed anymore, but also that am not able to attach a debugging session or deploy new code and I need to use MFDeploy to erase the current deployment before I can use the device again. Happens both on a N1 and a N2 device with latest stable firmware, so at least for now I've replaced the infinite sleep with some arbitrary sleep timeout depending bit on the scenario, 200-1000ms, and not seeing the issues anymore.
Not sure what's going wrong and if other seeing same behavior, but haven't spent time yet diving into the device's firmware code.
#3 Hachi'
Hachi'
  • 10 posts
  • LocationEurope
Posted 06 November 2013 - 06:06 AM
Thanks, for watching through my code.
Normally, Thread.Sleep(Timeout.Infinite) works fine, I never had such problems you described.
Also tagged with one or more of these keywords: Thread, Threading, SerialPort, AutoResetEvent, ManualResetEvent, WaitHandle
