The netduino's don't have the XML runtimes, because they take a lot of memory.
I wrote a (fairly crappy) xml reader. There are probably many things wrong with it, but it works for my purposes, maybe it will work for you.
namespace Data{ public class XmlReader { private string mstrInput; private string mstrName; private int mintCurrentPosition; private System.Collections.Stack mobjStack = new System.Collections.Stack(); public XmlReader(string Input) { mstrInput = Input; mintCurrentPosition = 0; } public bool Read() { // find the next <element> int intElementSpace = 0; int intElementNameEnd = 0; bool blnElementFound = false; while (!(blnElementFound || mintCurrentPosition >= mstrInput.Length)) { switch (mstrInput.Substring(mintCurrentPosition, 1)) { case "<": // element start (or end) if (mstrInput.Substring(mintCurrentPosition, 2) == "</") { // element end mstrName = mobjStack.Peek().ToString(); if (mstrInput.Substring(mintCurrentPosition, mstrName.Length + 3) == "</" + mstrName + ">") { // long-form element close, pop the current stack item mobjStack.Pop(); } mintCurrentPosition = mintCurrentPosition + (mstrName.Length + 3); } else { // element start if (mstrInput.Substring(mintCurrentPosition, 2) == "<?") { // xml or other declaration, skip intElementNameEnd = mstrInput.Substring(mintCurrentPosition).IndexOf(">"); mintCurrentPosition = mintCurrentPosition + intElementNameEnd; } else { intElementNameEnd = mstrInput.Substring(mintCurrentPosition).IndexOf(">"); intElementSpace = mstrInput.Substring(mintCurrentPosition).IndexOf(" "); if (intElementSpace > 0 && intElementSpace < intElementNameEnd) { mstrName = mstrInput.Substring(mintCurrentPosition + 1, intElementSpace - 1); mintCurrentPosition = mintCurrentPosition + intElementSpace + 1; } else { mstrName = mstrInput.Substring(mintCurrentPosition + 1, intElementNameEnd - 1); mintCurrentPosition = mintCurrentPosition + intElementNameEnd + 1; } mobjStack.Push(mstrName); blnElementFound = true; } } break; case "/": // short-form element close if (mstrInput.Substring(mintCurrentPosition, 2) == "/>") { // pop the current stack item mobjStack.Pop(); mstrName = mobjStack.Peek().ToString(); mintCurrentPosition = mintCurrentPosition + 2; } else { mintCurrentPosition = mintCurrentPosition + 1; } break; default: mintCurrentPosition = mintCurrentPosition + 1; break; } } return !(mobjStack.Count == 0) & !(mintCurrentPosition >= mstrInput.Length); } public string Name { get { return mstrName; } } public string GetAttribute(string Name) { string strDataLine = null; int intElementEnd = 0; string[] strAttributes = null; string[] strSplit = null; string strName = null; string strValue = null; intElementEnd = mstrInput.Substring(mintCurrentPosition).IndexOfAny(new char[] { '>', '<', '/' }); strDataLine = mstrInput.Substring(mintCurrentPosition, intElementEnd); strAttributes = strDataLine.Split(' '); foreach (string strAttribute in strAttributes) { if (strAttribute != string.Empty) { strSplit = strAttribute.Split('='); if (strSplit.Length == 2) { strName = strSplit[0]; strValue = strSplit[1]; strValue = XMLSerializer.Unescape(strValue.Substring(1, strValue.Length - 2)); if (strName == Name) { return strValue; } } } } return ""; } public Collections.DictionaryEntry[] GetAttributes() { string strDataLine = null; int intElementEnd = 0; string[] strAttributes = null; string[] strSplit = null; string strName = null; string strValue = null; System.Collections.ArrayList objAttributes = new System.Collections.ArrayList(); intElementEnd = mstrInput.Substring(mintCurrentPosition).IndexOfAny(new char[] { '>', '<', '/' }); strDataLine = mstrInput.Substring(mintCurrentPosition, intElementEnd); strAttributes = strDataLine.Split(' '); foreach (string strAttribute in strAttributes) { if (strAttribute != string.Empty) { strSplit = strAttribute.Split('='); if (strSplit.Length == 2) { strName = strSplit[0]; strValue = strSplit[1]; // remove quotes strValue = XMLSerializer.Unescape(strValue.Substring(1, strValue.Length - 2)); objAttributes.Add(new System.Collections.DictionaryEntry(strName, strValue)); } } } return (Collections.DictionaryEntry[])objAttributes.ToArray(typeof(Collections.DictionaryEntry)); } }}
