N+2 Socket problem
Best Answer cce1911, 29 July 2013 - 02:40 PM
I found the problem with my code. In the server app, the 2nd while loop should have had totalread instead of 0 for the second parameter of the .receive call. I was overwriting the data each time. Maybe this will help someone in the future...
Go to the full post
#1 cce1911
cce1911
  • 71 posts
  • LocationGeorgia, USA
Posted 24 July 2013 - 07:42 PM
I'm new to sockets and just can't seem to get my app working. What I want to do is send a log file from the N+2 back to my laptop. The approach I took was to prepend the file size to the byte array before sending. However, I never seem to receive exactly what I send. I realize this is a very common problem with folks who are new to sockets and I've searched high and low to find tips on how to avoid this problem. Maybe this is something unique to N+2, but I kind of doubt it.
Here is my code. I've got a client app that runs on the N+2 and a console app running on my laptop. The data file I'm retrieving is attached below. This sort of works, but is not delivering the file consistently. Any help you can give me would be appreciated.
Client app running on N+2. When you press the onboard button, it sends the file.
[font="'courier new', courier, monospace;"]using System;
using System.Net;
using System.Net.Sockets;
using System.Text;
using System.IO;
using SecretLabs.NETMF.Hardware.Netduino;[/font]
[font="'courier new', courier, monospace;"]namespace SocketClient
  {[/font]
[font="'courier new', courier, monospace;"]   public class Program
  static string strDeviceIP = "";
  static string strDeviceSubnet = "";
  static string strDeviceGateway = "";
  static string strDevicePort = "";
  static string strControllerIP = "";[/font]
[font="'courier new', courier, monospace;"]   public static OutputPort opLED = new OutputPort(Pins.GPIO_PIN_D13, false);
  InputPort button = new InputPort(Pins.ONBOARD_SW1, false, Port.ResistorMode.Disabled);[/font]
[font="'courier new', courier, monospace;"]   public static void Main()
  strDeviceIP = "192.168.2.102";
  strDeviceSubnet = "255.255.255.0";
  strDeviceGateway = "192.168.2.2";
  strControllerIP = "192.168.2.222";
  strDevicePort = "9999";
  InterruptPort btn = new InterruptPort(Pins.ONBOARD_SW1, false,[/font]
[font="'courier new', courier, monospace;"]Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeLow);
  btn.OnInterrupt += new NativeEventHandler(ButtonPress);[/font]
[font="'courier new', courier, monospace;"]   while (true)
  }[/font]
[font="'courier new', courier, monospace;"]   public static void ButtonPress(uint data1, uint data2, DateTime time)
  opLED.Write(true);[/font]
[font="'courier new', courier, monospace;"]   Socket socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
  IPAddress hostAddress = IPAddress.Parse(strControllerIP);
  IPEndPoint endpoint = new IPEndPoint(hostAddress, Int32.Parse(strDevicePort));[/font]
[font="'courier new', courier, monospace;"]   string fileName = "runlog2.txt";
  // read the file into a byte array
  byte[] data = File.ReadAllBytes(@"SD" + fileName);
  byte[] sizeinfo = new byte[4];
  byte[] senddata = new byte[4 + data.Length];[/font]
[font="'courier new', courier, monospace;"]   // check to make sure it's not too big
  if (data.Length > 850 * 1024)
  Debug.Print("File too large");
  }[/font]
[font="'courier new', courier, monospace;"]   // convert data.length into a byte array
  sizeinfo[0] = (byte)data.Length;
  sizeinfo[1] = (byte)(data.Length >> 8);
  sizeinfo[2] = (byte)(data.Length >> 16);
  sizeinfo[3] = (byte)(data.Length >> 24);[/font]
[font="'courier new', courier, monospace;"]   // prepend the size into the senddata array
  sizeinfo.CopyTo(senddata, 0);[/font]
[font="'courier new', courier, monospace;"]   // copy read data into the senddata array
  data.CopyTo(senddata, 4);[/font]
[font="'courier new', courier, monospace;"]   // send the data
  socket.Connect(endpoint);
  socket.Send(senddata);
  socket.Close();
  opLED.Write(false);
  }[/font]
[font="'courier new', courier, monospace;"]Here is my server side console app.[/font]
[font="'courier new', courier, monospace;"] [/font]
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.IO;
using System.Net;
using System.Collections;
using System.Threading;[/font]
[font="'courier new', courier, monospace;"]namespace SocketConsole
  class Program
  static void Main(string[] args)
  Thread thread1 = new Thread(new ThreadStart(Listener));
  thread1.Start();[/font]
  }[/font]
[font="'courier new', courier, monospace;"] public static void Listener()
  try
  Socket sktMain = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
  sktMain.Bind(new IPEndPoint(IPAddress.Parse("192.168.2.222"), 9999));
  sktMain.Listen(10);
  var message = new ArrayList();[/font]
  // create the client socket
  using (var client = sktMain.Accept())
  //If connected,
  if (SocketConnected(client, 100))
  while (SocketConnected(client, 100))
  byte[] sizeinfo = new byte[4];[/font]
[font="'courier new', courier, monospace;"]   //read the size of the message into sizeinfo
  int totalread = 0, currentread = 0;
  currentread = totalread = client.Receive(sizeinfo, 4, SocketFlags.None);[/font]
[font="'courier new', courier, monospace;"]   while (totalread < sizeinfo.Length && currentread > 0)
  currentread = client.Receive(sizeinfo, totalread, sizeinfo.Length - totalread, SocketFlags.None);
  totalread += currentread;
  }[/font]
[font="'courier new', courier, monospace;"]   int messagesize = 0;
  messagesize |= sizeinfo[0];
  messagesize |= (((int)sizeinfo[1]) << 8);
  messagesize |= (((int)sizeinfo[2]) << 16);
  messagesize |= (((int)sizeinfo[3]) << 24);[/font]
[font="'courier new', courier, monospace;"]   byte[] data = new byte[messagesize];
  totalread = 0;
  currentread = totalread = client.Receive(data, 0, data.Length - totalread, SocketFlags.None);
  var received = Encoding.UTF8.GetChars(data);[/font]
[font="'courier new', courier, monospace;"]   int diff = data.Length - totalread;[/font]
[font="'courier new', courier, monospace;"]   while (totalread < messagesize && currentread > 0)
  currentread = client.Receive(data, 0, data.Length - totalread, SocketFlags.None);
  for (var i = 0; i < received.Length; i++)
  message.Add(received[i]);
  string fName = "runlog.txt";
  if (File.Exists(fName)) File.Delete(fName);[/font]
[font="'courier new', courier, monospace;"]   BinaryWriter bWrite = new BinaryWriter(File.Open(fName, FileMode.Create));
  bWrite.Write(data);
  bWrite.Close();
  catch (Exception ex)
  Console.WriteLine(ex.Message);
  }[/font]
[font="'courier new', courier, monospace;"] // socket polling
static bool SocketConnected(Socket s, int ms)
return !(s.Poll(ms, SelectMode.SelectRead) & (s.Available == 0));
}[/font]
[font="'courier new', courier, monospace;"]   }
  }[/font]
#2 cce1911
cce1911
  • 71 posts
Posted 25 July 2013 - 03:15 AM
If I look at the byte array data, after receiving all the data, every byte above 255 has a value of 0. It's as if it stops reading at 255. If I debug.print in the while loop filling "data", I get the following output:
client accepting data client.Receive sizeinfo: currentread = 4, totalread = 4 total message size = 3296 client.Receive data: currentread = 252, totalread = 252 client.Receive data: currentread = 256 totalread = 508 client.Receive data: currentread = 256 totalread = 764 client.Receive data: currentread = 256 totalread = 1020 client.Receive data: currentread = 256 totalread = 1276 client.Receive data: currentread = 256 totalread = 1532 client.Receive data: currentread = 256 totalread = 1788 client.Receive data: currentread = 256 totalread = 2044 client.Receive data: currentread = 256 totalread = 2300 client.Receive data: currentread = 256 totalread = 2556 client.Receive data: currentread = 256 totalread = 2812 client.Receive data: currentread = 256 totalread = 3068 client.Receive data: currentread = 228 totalread = 3296 client.Receive data final: currentread = 228 totalread = 3296
So it is accepting 256 bytes each time, but they are all zero. Obviously, I don't understand what's going on:(
#3 cce1911
cce1911
  • 71 posts
Posted 29 July 2013 - 02:40 PM   Best Answer
#4 elettrozero
elettrozero
  • 58 posts
Posted 11 August 2013 - 07:41 AM
Hi cce, may I ask you how many clients can you connect at the same time to the server? Tkx
#5 cce1911
cce1911
  • 71 posts
Posted 11 August 2013 - 12:52 PM
Zero, so far I have only tested with a single client.
#6 elettrozero
elettrozero
  • 58 posts
Posted 11 August 2013 - 04:25 PM
:) Allright tkx
