Plus 2 with PCA9685 16 channel PWM Controller (I2C)
7 replies to this topic
#1 iced98lx
iced98lx
  • 134 posts
  • LocationSouth Dakota
Posted 16 April 2013 - 11:45 PM
Okay, so I've updated my N+2 to 4.2.2.2 and I am transitioning my PWM controls off the on board (since I need 15) to the AdaFruit 16 channel 12 bit PWM controller. (http://www.adafruit.com/products/815). I've got it hooked up as such:
Netduino + 2 SC Pin -> SCL Pin (Pullup off 3.3v with a 2.2k)
Netduino + 2 SD Pin -> SDA Pin (Pullup off 3.3v with a 2.2k)
3.3v -> VCC
GND -> GND
Here is how it is set up:
Posted Image
I am using the 'driver' class from http://forums.netdui...wms/#entry42442
and executing the following:
Adafruit_PWMServoDriver Light1 = new Adafruit_PWMServoDriver();Light1.setPWMFreq(100);Light1.setPWM(4, 0, 200);
I don't have a scope, so I'm sort of flying blind but with the PWM of channel 4 hooked up to a channel that works if I control it directly from the N+2 nothing changes when I set it as displayed, it's at 100%.
I'm a 100% newbie on i2c stuff, BrandonW6's driver doesn't mean too much to me, where can I start troubleshooting?
#2 NooM
NooM
  • 490 posts
Posted 17 April 2013 - 10:24 AM
did you try connecting it to sda and scl makred pins on netduino?
#3 iced98lx
iced98lx
  • 134 posts
Posted 17 April 2013 - 01:56 PM
Indeed, that is how I have had it set up from the start- the diagram hooked to analog 4 and 5 with no pullups is from AdaFruit's website, showing how they suggest connecting it to a UNO. I posted it as a "Should I connnect it like this instead?!"  Perhaps it'd help if I made my own diagram? I have tried it without the pullups with no further success.
#4 NooM
NooM
  • 490 posts
Posted 17 April 2013 - 02:29 PM
have you made the update to 4.2.2.2 ?
#5 iced98lx
iced98lx
  • 134 posts
Posted 17 April 2013 - 05:23 PM
Yes.
#6 iced98lx
iced98lx
  • 134 posts
Posted 17 April 2013 - 06:13 PM
updated original post to show how I've attached it.
#7 iced98lx
iced98lx
  • 134 posts
Posted 17 April 2013 - 10:01 PM
NooM Helped me break it down and just check to see if my hardware works, and it does appear to be working- I can read / write
#8 iced98lx
iced98lx
  • 134 posts
Posted 18 April 2013 - 02:11 AM
Alright, so - the diagram above works fine.
You can find the driver I ended up using in this thread:http://forums.netdui...y-pwms/?p=48501
But the long and short is things are working well.
