Hi!
Anybody has experience SB with DFRobot L298P using HBridge, no errors motor doesn't rotate
Here the code
Toolbox HBridge with SB
Started by eplaksienko, Mar 29 2013 02:30 AM
#1Posted 29 March 2013 - 02:30 AM Hi!
Here the code
using System; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using NetduinoGo; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.NetduinoGo; using Toolbox.NETMF.Hardware; namespace DFRobotMShield { public class Program { public static void Main() { // write your code here Thread.Sleep(5000); NetduinoGo.ShieldBase sb = new NetduinoGo.ShieldBase((GoBus.GoSocket)4); HBridge MotorDriver = new HBridge(sb.PWMChannels.PWM_PIN_D6, sb.Pins.GPIO_PIN_D7, sb.PWMChannels.PWM_PIN_D5, sb.Pins.GPIO_PIN_D4); MotorDriver.SetState(HBridge.Motors.Motor1, -50); //Thread.Sleep(Timeout.Infinite); while (true) ; } } }
#2Posted 29 March 2013 - 08:03 AM Hi,
From the manual; http://www.dfrobot.c...N)_(SKU:DRI0009) You can select PWM and PPL mode with jumpers. The only supported mode with this class is PWM. Could you check if you have your jumpers set correctly?
Also, what are the specifications of your motors and power supply? Do the motors make a sound? It can be that they just won't get enough power.
My .NETMF projects: .NETMF Toolbox / Gadgeteer Light / Some PCB designs #3Posted 29 March 2013 - 12:23 PM Thanks Stefan, I found the solution from absolutely different angle , but without your tip I wouldn't get it, it's somehow different MS, no PWM/PLL switch, and what happened it was different pins I will post later today pic of the shield, but it was shipped by robotshop.com in dfrobot wrappinf with df robot logo on it
Actually is there class to control stepper with it? 0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
