I got an error when deploy piezo. An error message box pop up "An unhandled exception of type 'System.Exception' occurred in mscorlib.dll".. Can anyone please help me where is the problem?
mscorlib.dll error
Started by zee, Mar 12 2013 07:06 AM
#1Posted 12 March 2013 - 07:06 AM Hi,
I got an error when deploy piezo. An error message box pop up "An unhandled exception of type 'System.Exception' occurred in mscorlib.dll".. Can anyone please help me where is the problem? #2Posted 12 March 2013 - 08:44 AM Hi Zee,
Could you please post some code? Right now, that error could mean anything
My .NETMF projects: .NETMF Toolbox / Gadgeteer Light / Some PCB designs #3Posted 12 March 2013 - 08:58 AM Hi Stefan,
Here's the code below:
public static void Main() { // write your code here // store the notes on the music scale and their associated pulse lengths System.Collections.Hashtable scale = new System.Collections.Hashtable(); // low octave scale.Add("c", 1915u); scale.Add("d", 1700u); scale.Add("e", 1519u); scale.Add("f", 1432u); scale.Add("g", 1275u); scale.Add("a", 1136u); scale.Add("b", 1014u); // high octave scale.Add("C", 956u); scale.Add("D", 851u); scale.Add("E", 758u); // silence ("hold note") scale.Add("h", 0u); int beatsPerMinute = 90; int beatTimeInMilliseconds = 60000 / beatsPerMinute; // 60,000 milliseconds per minute int pauseTimeInMilliseconds = (int)(beatTimeInMilliseconds * 0.1); // define the song (letter of note followed by length of note) string song = "C1C1C1g1a1a1g2E1E1D1D1C2"; // define the speaker PWM speaker = new PWM(Pins.GPIO_PIN_D5); // interpret and play the song for (int i = 0; i < song.Length; i += 2) { // extract each note and its length in beats string note = song.Substring(i, 1); int beatCount = int.Parse(song.Substring(i + 1, 1)); // look up the note duration (in microseconds) uint noteDuration = (uint)scale[note]; // play the note for the desired number of beats speaker.SetPulse(noteDuration * 2, noteDuration); Thread.Sleep( beatTimeInMilliseconds * beatCount - pauseTimeInMilliseconds); // pause for 1/10th of a beat in between every note. speaker.SetDutyCycle(0); Thread.Sleep(pauseTimeInMilliseconds); } Thread.Sleep(Timeout.Infinite); } Thanks for your help!
#4Posted 12 March 2013 - 09:07 AM Sorry.. the PWM i editted it to SecretLabs.NETMF.Hardware.PWM speaker = new SecretLabs.NETMF.Hardware.PWM(Pins.GPIO_PIN_D5); #5Posted 12 March 2013 - 09:17 AM Sorry Stefan.. My typo error.. Instead of 'i', I accidentally typed '1'..
instead of :
string note = song.Substring(i, 1); int beatCount = int.Parse(song.Substring(i + 1, 1)); My silly mistakes: string note = song.Substring(1, 1); int beatCount = int.Parse(song.Substring(1 + 1, 1));
Sorry for the Inconveniences cause.. #6Posted 13 March 2013 - 04:46 AM
Hi zee,
Which line of code is causing the exception?
Try setting a breakpoint on the first line of your code and then press F8 to run one line of code. When that's done, press F8 again. Repeat until you get the exception.
1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | ||||||||||||||
