I got an error when deploy piezo. An error message box pop up "An unhandled exception of type 'System.Exception' occurred in mscorlib.dll".. Can anyone please help me where is the problem?
![]() mscorlib.dll error
Started by zee, Mar 12 2013 07:06 AM
Posted 12 March 2013 - 07:06 AM Hi,
Posted 12 March 2013 - 08:44 AM Hi Zee,
Could you please post some code? Right now, that error could mean anything
Posted 12 March 2013 - 08:58 AM Hi Stefan,
Here's the code below:
public static void Main() { // write your code here // store the notes on the music scale and their associated pulse lengths System.Collections.Hashtable scale = new System.Collections.Hashtable(); // low octave scale.Add("c", 1915u); scale.Add("d", 1700u); scale.Add("e", 1519u); scale.Add("f", 1432u); scale.Add("g", 1275u); scale.Add("a", 1136u); scale.Add("b", 1014u); // high octave scale.Add("C", 956u); scale.Add("D", 851u); scale.Add("E", 758u); // silence ("hold note") scale.Add("h", 0u); int beatsPerMinute = 90; int beatTimeInMilliseconds = 60000 / beatsPerMinute; // 60,000 milliseconds per minute int pauseTimeInMilliseconds = (int)(beatTimeInMilliseconds * 0.1); // define the song (letter of note followed by length of note) string song = "C1C1C1g1a1a1g2E1E1D1D1C2"; // define the speaker PWM speaker = new PWM(Pins.GPIO_PIN_D5); // interpret and play the song for (int i = 0; i < song.Length; i += 2) { // extract each note and its length in beats string note = song.Substring(i, 1); int beatCount = int.Parse(song.Substring(i + 1, 1)); // look up the note duration (in microseconds) uint noteDuration = (uint)scale[note]; // play the note for the desired number of beats speaker.SetPulse(noteDuration * 2, noteDuration); Thread.Sleep( beatTimeInMilliseconds * beatCount - pauseTimeInMilliseconds); // pause for 1/10th of a beat in between every note. speaker.SetDutyCycle(0); Thread.Sleep(pauseTimeInMilliseconds); } Thread.Sleep(Timeout.Infinite); } Thanks for your help!
Posted 12 March 2013 - 09:07 AM Sorry.. the PWM i editted it to SecretLabs.NETMF.Hardware.PWM speaker = new SecretLabs.NETMF.Hardware.PWM(Pins.GPIO_PIN_D5);
Posted 12 March 2013 - 09:17 AM Sorry Stefan.. My typo error.. Instead of 'i', I accidentally typed '1'..
instead of :
string note = song.Substring(i, 1); int beatCount = int.Parse(song.Substring(i + 1, 1)); My silly mistakes: string note = song.Substring(1, 1); int beatCount = int.Parse(song.Substring(1 + 1, 1));
Sorry for the Inconveniences cause..
Posted 13 March 2013 - 04:46 AM
Hi zee,
Which line of code is causing the exception?
Try setting a breakpoint on the first line of your code and then press F8 to run one line of code. When that's done, press F8 again. Repeat until you get the exception.
0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
This webpage is licensed under a Creative Commons Attribution-ShareAlike License. | ![]() |
