Analog Input - Photocell and Webpage
#1 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 06 December 2010 - 12:17 AM
I made this to show you another way to output your photocell's data. I have spent hours playing with this, don't waste too much time ;). I hope you enjoy this! I'll post the schematics for the photocell here too.
Use the code below with Fred's Web Server code. (http://forums.netdui...ted-web-server/)
using System.IO;
using Ethernet.Data;
namespace NetduinoPlusWebServer
        static AnalogInput photcell;
            Listener webServer = new Listener(RequestReceived);
            OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);
            photcell = new AnalogInput(Pins.GPIO_PIN_A5);
            photcell.SetRange(0, 255);
                // Blink LED to show we're still responsive
                led.Write(!led.Read());
                Thread.Sleep(500);
        private static void RequestReceived(Request request)
            int shade = photcell.Read();
            request.SendResponse(
                "<html>" +
                "<header> <meta http-equiv=\"refresh\" content=\"2\"></header>" +
                "<body style=\"background-color: rgb(" + shade + "," + shade + "," + shade + ")\">" +
                "<p> Time (relative to start time): " + DateTime.Now.ToString() + "</p>" +
                "<p> Value: " + shade + "</p>" +
                "</body>" +
                "</html>"
Thanks a bunch for the web server code Fred!
#2 ThingSpeak
ThingSpeak
  • 13 posts
Posted 27 January 2011 - 06:13 AM
Thanks for the video, it was helpful for me in my tutorial preparation.
#3 Earthed
Earthed
  • 20 posts
  • LocationAustralia
Posted 30 August 2011 - 11:03 PM
if using 4.2 RC1: take a look at this http://forums.netdui...7292#entry17292
#4 Larsey
Larsey
  • 38 posts
Posted 06 March 2013 - 08:48 PM
Hello Omar :-)
Silly question, but why is the resistor placed after the photocell and to the ground?
#5 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 06 March 2013 - 09:51 PM
Hello Omar :-)
This is called a Pull-Down resistor.  You may have heard of Pull-Up resistors.  Pull-Up and Pull-Down resistors are used to put a point in a that may be attached to an input into a defined state as opposed to letting it simply float.  Many designers follow a simple rule of never leaving your inputs floating even ones that have nothing connected to them. But this applies typically to digital inputs to be sure we have clear 0 and 1 states.
For analog inputs, sometimes an input needs a DC bias. This can be done using a simple resistive voltage divider-- which also looks like a pull-up + pull-down. Normally in this case there is also something that is resisting the DC, like a capacitor or in this case the photocell.  The photocell likely has it's own resistive value so the need for the pull-up is not necessary in this case.
