I figured that if I ran 4.2.x of the firmware on both, as well as 4.2.0.0 of the CLR, it should work. However, when I run my project at home, I immediately get an error like the following one in the output window:
Failed allocation for 24 blocks, 288 bytes
This usually prints over and over again. I read somewhere that it's technically not a fatal error, but what happens is that eventually the program crashes, and on a line in my code that doesn't make sense ( SerialPort.open() -- why would it fail when it's one of the first-constructed objects?). Other times, it runs, but extremely slowly and only occasionally seems to be able to pull bytes out of the serial buffer.
I was hoping that someone could enlighten me on this issue. Perhaps something from MFDEPLOY will make it really obvious what I'm doing wrong:
Work setup (working on N+2) -- output window messages + MFDEPLOY
Work Create TS. Loading start at 806a238, end 8085f74 Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0) Assembly: Microsoft.SPOT.Net (4.2.0.0) Assembly: System (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.IO (4.2.0.0) Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0) Assembly: SecretLabs.NETMF.Diagnostics (4.2.0.0) Assembly: SecretLabs.NETMF.Hardware.Netduino (4.2.1.0) Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0) Assembly: Microsoft.SPOT.Time (4.2.0.0) Loading Deployment Assemblies. Attaching deployed file. Assembly: AmuletLibrary (1.0.0.0) Attaching deployed file. Assembly: SecretLabs.NETMF.Hardware (4.2.0.0) Resolving. The debugging target runtime is loading the application assemblies and starting execution. Ready. The thread '<No Name>' (0x2) has exited with code 0 (0x0). MFDeploy (work) Pinging... TinyCLR HalSystemInfo.halVersion: 4.2.0.0 HalSystemInfo.halVendorInfo: Netduino Plus 2 (v4.2.1.0) by Secret Labs LLC HalSystemInfo.oemCode: 34 HalSystemInfo.modelCode: 177 HalSystemInfo.skuCode: 4102 HalSystemInfo.moduleSerialNumber: 00000000000000000000000000000000 HalSystemInfo.systemSerialNumber: 0000000000000000 ClrInfo.clrVersion: 4.2.0.0 ClrInfo.clrVendorInfo: Netduino Plus 2 (v4.2.1.0) by Secret Labs LLC ClrInfo.targetFrameworkVersion: 4.2.0.0 SolutionReleaseInfo.solutionVersion: 4.2.1.0 SolutionReleaseInfo.solutionVendorInfo: Netduino Plus 2 (v4.2.1.0) by Secret Labs LLC SoftwareVersion.BuildDate: Nov 7 2012 SoftwareVersion.CompilerVersion: 410894 FloatingPoint: True SourceLevelDebugging: True ThreadCreateEx: True LCD.Width: 0 LCD.Height: 0 LCD.BitsPerPixel: 0 AppDomains: True ExceptionFilters: True IncrementalDeployment: True SoftReboot: True Profiling: False ProfilingAllocations: False ProfilingCalls: False IsUnknown: False
Home setup (not working on N+):
Home Found debugger! Create TS. Loading start at 1542e0, end 16c5dc Assembly: mscorlib (4.2.0.0) Assembly: System (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.IO (4.2.0.0) Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Assembly: SecretLabs.NETMF.Diagnostics (4.2.0.0) Loading Deployment Assemblies. Attaching deployed file. Assembly: SecretLabs.NETMF.Hardware.Netduino (4.2.1.0) Attaching deployed file. Assembly: AmuletLibrary (1.0.0.0) Attaching deployed file. Assembly: SecretLabs.NETMF.Hardware (4.2.0.0) Resolving. The debugging target runtime is loading the application assemblies and starting execution. Ready. MFDeploy (home) Pinging... Pinging... Pinging... Failed allocation for 23 blocks, 276 bytes TinyCLR Pinging... TinyCLR HalSystemInfo.halVersion: 4.2.0.0 HalSystemInfo.halVendorInfo: Netduino Plus (v4.2.0.1) by Secret Labs LLC HalSystemInfo.oemCode: 255 HalSystemInfo.modelCode: 255 HalSystemInfo.skuCode: 65535 HalSystemInfo.moduleSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF HalSystemInfo.systemSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ClrInfo.clrVersion: 4.2.0.0 ClrInfo.clrVendorInfo: Netduino Plus (v4.2.0.1) by Secret Labs LLC ClrInfo.targetFrameworkVersion: 4.2.0.0 SolutionReleaseInfo.solutionVersion: 4.2.0.0 SolutionReleaseInfo.solutionVendorInfo: Netduino Plus (v4.2.0.1) by Secret Labs LLC SoftwareVersion.BuildDate: Sep 19 2012 SoftwareVersion.CompilerVersion: 410894 FloatingPoint: True SourceLevelDebugging: True ThreadCreateEx: True LCD.Width: 0 LCD.Height: 0 LCD.BitsPerPixel: 0 AppDomains: True ExceptionFilters: True IncrementalDeployment: True SoftReboot: True Profiling: False ProfilingAllocations: False ProfilingCalls: False IsUnknown: False
Any help would be greatly appreciated! I would normally just shell out another $60 and not worry about it, but since my project is OSS, I'd like it to work on the Netduino/Plus/2.
