Serial LCD and Netduino Plus 2
#1 don664
don664
  • 77 posts
  • LocationHillcrest, KZN, South Africa
Posted 20 November 2012 - 08:02 AM
Hi there,
After struggling with this for a day I finally got it working and thought I'd share.
The problem seemed to be with the declaration syntax (sorry if I'm using the wrong terminology here) between .Net Micro Framework 4.1 and 4.2.
For example the class I was trying to use declared the serial port like this:
_lcd = new SerialPort(com, 9600, Parity.None, 8, StopBits.One);
Yet it needs to be like this:
_lcd = new System.IO.Ports.SerialPort(com, 9600, System.IO.Ports.Parity.None, 8, System.IO.Ports.StopBits.One);
Once I sorted that out it all seems to be working just fine now. This syntax was corrected by right clicking on the red underlined text, such as SerialPort, and selecting "Resolve"... IntelliSense does the rest for you ;)
Here's the LCD class (LCD.cs):
namespace slcdHelloWorld
    class LCD
        private System.IO.Ports.SerialPort _lcd;
        private byte[] clear = { 0xFE, 0x01 };
        private byte[] blinkboxon = { 0xFE, 0x0D };
        private byte[] blinkboxoff = { 0xFE, 0x0C };
        public LCD(string com)
            _lcd.Open();
            this.Clear();
            this.MoveCur(0);
            this.Write(blinkboxoff);
        public void Clear()
            this.Write(clear);
            this.MoveCur(0);
        public void Write(byte[] B)
            _lcd.Write(b, 0, b.Length);
        public void MoveCur(int i)
            this.Write(blinkboxon);
            if (i > 15) i += 48;
            byte locByte = (byte)(128 + i);
            byte[] moveto = { 0xFE, locByte };
            Debug.Print("MoveTo - " + moveto[0].ToString() + " - " + moveto[1].ToString() + " - locByte " + locByte.ToString());
            this.Write(moveto);
And here's the Program.cs:
using System.Net;
using System.Net.Sockets;
        // initialise the LCD display
        static LCD mylcd = new LCD("COM2");
            // write your code here
            while (true)            {
                mylcd.Clear();
                byte[] bytes = System.Text.Encoding.UTF8.GetBytes("Hello World");
                mylcd.Write(bytes);
                Thread.Sleep(5000);
                mylcd.Clear();
                mylcd.MoveCur(30);
In terms of connecting up the Serial LCD (https://www.sparkfun.com/products/9395) simply run wires like this (LCD to Netduino):
Posted Image
Thanks to everyone for the help and hope this saves someone else some time :D
Cheers,
Donovan
#2 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 20 November 2012 - 11:52 AM
You can also do: using System.IO.Ports; Then you don't need to preface everything with System.IO.Ports
#3 don664
don664
  • 77 posts
Posted 20 November 2012 - 12:21 PM
Ah ha! Thanks Dave :D
#4 Chuckles
Chuckles
  • 40 posts
Posted 17 June 2013 - 01:45 AM
Hi Donovan. Both that part and then one at https://www.sparkfun.com/products/9568 seem to require 5V. How did you deal with that?
Thanks.
#5 don664
don664
  • 77 posts
Posted 18 June 2013 - 10:12 AM
Hi Chuckles,
The supplier I use offers a 3.3V Serial LCD: http://www.netram.co...tml?keyword=lcd
Cheers,
Donovan
