Some questions about Netduino Go
Posted 10 October 2012 - 03:14 PM
First off, even through the limited selection of modules (atm), and the annoying Erase/Flash/Deploy bug, I'm quite impressed by the Go, and from what it looks like, lot's of great stuff are happening in the future! But when that's said, I've got a few questions. My knowledge in hardware is very limited, but I think I got the basics.
1. Memory capacity
Is it possible, in any way, to expand the code- and/or memory space on the Netduino Go? Can the code space be made able for memory?
If the answer is no, does anyone have to experience/recommendations on how to do so? Currently I've got a NGo and a N+ connected through serial, where the N+ is acting like a modem/storagedevice. The connection is made through the COM-ports, is this the best method?
2. Socket expansion
Are there any plans for a module which expands the total number of sockets?
3. Power capacity
How much stuff can the NGo power? Imagine a couple of Shieldbases, a dozen of relays, Ethernet module, SD Module, touch display and some more.. That would require an external power supply, right?
4. Remote updating
Since the NGo is able to flash the Shieldbase, is it then possible to make another device flash a NGo?
5. Reset
Is it somehow possible to attach a reset wire to the NGo?
6. SPI
I've read a little about SPI, but I'm not sure if I get it. Does SPI make it possible to establish a serial-connection with multiple devices through the same three wires?
Thanks.
ntools
TCP Listener (Beta) · FTP Server (Alpha)
Netduino Plus Go Module · Xml Parser
http://ntools.codeplex.com/
Posted 10 October 2012 - 03:24 PM
I probably can't answer all questions to your satisfaction, but since I should know some stuff about the subject I'll try
Thank you very much!First off, even through the limited selection of modules (atm), and the annoying Erase/Flash/Deploy bug, I'm quite impressed by the Go, and from what it looks like, lot's of great stuff are happening in the future!
Code memory: I leave that open for Chris.1. Memory capacity
Other memory: There is an SD module in the making, which makes it possible to use SD cards as storage. This can be used as memory.
Yes. The possibility for a Netduino Go! Hub has recently been announced. There's no date mentioned as far as I know, but it's something that will be possible in the future.2. Socket expansion
It would indeed require some power. The Netduino Go! Hub design comes with a power barrel to supply power to it's modules.3. Power capacity
Advanced topic. You may have noticed there are 10 empty holes on the mainboard. It's possible to solder JTAG pins onto it and program+debug with a JTAG debugger.4. Remote updating
No, but in code you could make a button module for example execute a reset. Also, an interrupt on the shieldbase will be able to do such a thing.5. Reset
Something like that. http://en.wikipedia....l_Interface_Bus could be a nice page to read for you!6. SPI
- Arron Chapman likes this
Posted 10 October 2012 - 03:40 PM
ntools
Posted 10 October 2012 - 03:51 PM
As Stefan alluded to, you can load assemblies via reflection from external storage like an SD card. They'll load into your available RAM though, so you'd want to only load the assemblies you actually needed. These are microcontroller boards and while NETMF makes them really powerful they're not really designed for huge applications.1. Memory capacity
It's not currently possible to add RAM externally (partially because you'd want a _really_ fast memory bus for that). If there's enough demand for extra RAM, we could create a higher-end Netduino Go in the future with additional on-board RAM.
3. Power capacity
Netduino Go can provide up to ~500 mA of power to directly-connected modules. Each powered hub can provide additional power for downstream modules too.
4. Remote updating
We could enable reflashing over an Ethernet or Serial module in a future update. Today you'll want to use USB.
5. Reset
We'll be enabling the pushbutton on Netduino Go as a reset button. There is also a watchdog on the microcontroller which we could logically hook up to an external GoBus button/module/IO. Or kicked via code...lots of options to explore.About the reset.. does that mean, that if the NGo hangs, there is no way to reset it, except from cutting the power?
Posted 11 October 2012 - 06:01 AM
So that means what Stefan said ain't gonna be possible? Using SD as memory. I know that the unit will lose a lot of speed, but at some point it might be worth it.
Okay, just thought it might could be possible. Bummer... currently I have a 320 kb application which needs to be updateable... Might be time to clean up the Dpws/System.Http/System.Xml assemblies, sigh
So what you say are, if I need to ensure a stable product, I have to find another board than the NGo, since there is NO, and not coming, ANY method to reset a hanging system?
ntools
Posted 11 October 2012 - 08:43 AM
It's useful as memory, just not code memory. You can store resources to it, but also use it as virtual memory. Fabien, one of the guys behind Nwazet, once wrote a nice class for this: netduino.helpers.Helpers.VirtualMemory.So that means what Stefan said ain't gonna be possible? Using SD as memory. I know that the unit will lose a lot of speed, but at some point it might be worth it.
Posted 11 October 2012 - 08:52 AM
We may actually put some of those assemblies in the NETMF portion of the flash, which would free up more space for your application as well. There are a number of ways to work out the "in-field re-flashing" issues. Netduino Go's MCU has pretty impressive specs...let's see what capabilities we can work out.Okay, just thought it might could be possible. Bummer... currently I have a 320 kb application which needs to be updateable... Might be time to clean up the Dpws/System.Http/System.Xml assemblies, sigh
The watchdog, combined with an external IO, should work as well as a physical reset line. If the watchdog kick timer queries the IO and sees that it is asserted, it would simply not kick the watchdog and the board would reboot.So what you say are, if I need to ensure a stable product, I have to find another board than the NGo, since there is NO, and not coming, ANY method to reset a hanging system?
We're working on a fairly large firmware update for Netduino Go (4.2.0.3) but once it gets posted later this month I'd love to explore low-power modes, standby, watchdog capabilities, etc.
Posted 11 October 2012 - 09:01 AM
Aah okay, so I won't be able to load assemblies with reflection, and expect that to run, but datas and stuff can be placed in a VM?
Att: Chris, sounds like more great news! It seems like the most of my worries are going to be taken care of... this is indeed an interesting platform! I smell tons of potential here.
ntools
Posted 11 October 2012 - 09:22 AM
Oh yes, you can load assemblies with reflection too. Fabien wrote code for that too: netduino.helpers.Helpers.SDResourceLoader.Aah okay, so I won't be able to load assemblies with reflection, and expect that to run, but datas and stuff can be placed in a VM?
It wil require some memory on the device as well though; it'll load the assembly in the available memory.
Posted 11 October 2012 - 09:30 AM
Yeah, I'm already loading assemblies with reflection, but I was wondering if it was possible to load assemblies into a virtual memory...
ntools
Posted 11 October 2012 - 09:33 AM
Ahh, I fear that's not possible currently. Maybe with some firmware tweaks, but that's beyond my knowledge.Yeah, I'm already loading assemblies with reflection, but I was wondering if it was possible to load assemblies into a virtual memory...
Posted 11 October 2012 - 10:09 AM
Asbjørn
Posted 11 October 2012 - 10:51 AM
(*) The biggest weakness is missing native code translation (either JIT or AOT) and resource size limitation.
Posted 11 October 2012 - 04:15 PM
Posted 11 October 2012 - 04:35 PM
Asbjørn
