What Is an Arduino Shield and Why Should My Netduino Care?
Posted 23 July 2012 - 04:56 PM
I'm in the process of writing a series of articles for Channel 9 on using Arduino shields with the Netduino / Plus. The first installment of the series was posted yesterday: http://channel9.msdn...y-Netduino-Care
In this article, I also show how to interface a Touch Display module designed for Netduino Go! to a regular Netduino / Plus, which is a request that has come up often since we launched Go! modules.
http://www.youtube.com/watch?v=m0-RUMYaZEY
Cheers,
-Fabien.
Posted 23 July 2012 - 06:59 PM
I can't wait to see some more articles in this series, and maybe some more Arduino shields used as examples. Keep the great work coming!
Steve
Twiiter: https://twitter.com/Gutworks
Posted 23 July 2012 - 07:03 PM
Posted 25 July 2012 - 06:29 PM
So I have tried to replicate the project on a breadboard but discovered, after a lot of hunting for suitable resistors in my junk pile, that I have a damaged display. I was finally able to get it setup and working on my Plus only to find random pressure events firing, and an Invalid Command! error displaying. Thinking that I miswired my Touch Display, I quickly tested it on the Netduino Go!, only to find the same results. After inspecting the display with my eye loupe I have discovered a crack in the ribbon of which two wires are affected. I don't recall pouting as much, or for as long, since my Mother through out my G.I. Joe "Snake-Eyes: The Origin" comic as a young kid.
Touch Display, though you were my first, you will always be fondly remembered and missed. It just seems like last week when I turned you on and touched you ever so gently. I still remember your bright, fine-pitched glow, exuding beauty and colour. Maybe someday we'll meet again, but for now I need to save my money for the upcoming SD and Ethernet Modules.
As a side note, I also noticed that the links to the Bitbucket repository are not working and show "Access denied". I was able to get the source from the Netduino Helpers sample folder on CodePlex, so I think I have everything I need now. As for the busted display, it was neat to see it working on my Netduino Plus. Hopefully others can enjoy more than I have been able to!
Cheers,
Saddened Steve
Posted 25 July 2012 - 06:54 PM
Awesome and congrats!
The Invalid Command is typically caused by cables that are too long, such as the 30cm cable.only to find random pressure events firing, and an Invalid Command! error displaying.
That will do it. Can you do me a favor and take a magnified picture of the cracked ribbon and send it to me? Use "contact at nwazet dot com". I'd like to see where the crack is located. The good news is that I can offer you a replacement touch screen for $25: the touch display board is designed so that the display can be easily swapped out
Thanks for letting me know. I'll let the Channel 9 guys know about this issue: the links pointing to the BitBucket repository should not be in the article. The code is only on CodePlex as part of the 'netduino helpers'.
Cheers,
-Fabien.
- Gutworks likes this
Posted 25 July 2012 - 08:04 PM
Perfect! I have sent you the images and await instructions. The only thing that could make this scenario any better would be if you had a copy of G.I. Joe "Snake-Eyes: The Origin" handy
Merci beaucoup Fabien!
Steve
Posted 25 July 2012 - 08:19 PM
Also, I'm sorry, but we're fresh out of the "G.I. Joe Snake-Eyes: The Origin" copies ;-)
Cheers,
-Fabien.
Posted 26 July 2012 - 10:28 AM
Posted 26 July 2012 - 04:32 PM
Posted 27 July 2012 - 05:01 AM
It was a fun project, especially hunting for transistors in my broken electronics bin. I found a suitable one, however after running a few forward voltage tests using the diode check on an Agilent U1233A Multimeter, I was able to determine that the salvaged resistor was damaged in the process. For the sake of testing I used a transistor that had the bare minimum for the collector current (Ic). The other downfall was that the transistor was an ECB (Emmiter pin 1, Collector pin 2, and Base pin 3) instead of the EBC shown in the article. So please note the photo of the actual wiring is slightly different than the diagram. When I transfer this project over to a prototype board I plan on using the actual transistor suggested in the article. I have some proto board with 442 points that seems to be the perfect size to create a shield. The bill of materials in the article doesn't mention it, but I plan on using some I purchased from ebay.
Note: Unfortunately the link to purchase the transistor in the Coding4Fun article is broken. The links above should work.
You can find below a picture of the completed breadboard project, however do keep in mind that I damaged my Touch Display earlier — oddly enough a touch display is not a toy for a 2 year old — and have ordered a replacement screen from [nwazet. I must add, the service and swiftness of the shipment from [nwazet has been fantastic. Thank you.
You may also notice the handy Prototype shield with mini breadboard I am using. It was purchased from Dealextreme.com for a really good price with free shipping. Now to wait for my replacement screen and some fun projects to come on the Netduino Plus. In the mean time I will be playing with my Netduino Go! and the the Seven Segment Display Module from Komodex.com.
Thanks again for the article Fabien. Great work.
Cheers,
Steve
Touch Display_bb.png 48.52KB 35 downloads
2012-07-27_0002.jpg 544.1KB 38 downloads
Posted 27 July 2012 - 04:40 PM
Posted 28 July 2012 - 10:21 PM
Posted 30 July 2012 - 05:40 PM
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
