netdurino does not respond to MFDEPLOY
Posted 06 July 2012 - 09:52 PM
Posted 06 July 2012 - 10:15 PM
Can you provide a little bigger hint?
I cannot get netdurino to respond to MFdeploy. It knows the device is there on USB, but will not recieve any data back from it. I can send programs and run them. Hope i do not have a lemon....
A little more information would make it a lot easier to help.
Type card (Netduino Plus), What you are trying to do with MFdeploy (set IP , download firmware etc.).
A screen shot helps a lot that shows any errors, MFdeploy configuration or setup etc.
If the Netduino is loading software and working the Netduino is most likely okay.
Are you using "MFDeploy.exe" or "MFDeploy.exe.config". You want to use MFDeploy.EXE
Chuck
Go Gators
Posted 06 July 2012 - 10:51 PM
Posted 07 July 2012 - 12:21 AM
Select Device -> USB, should show Netduino_Netduino
Press ping, should show Pinging... TinyCLR
Select Target -> Device Capabilities, it should show something like the attached JPeg.
Chuck
Posted 07 July 2012 - 12:54 AM
Run MFDeploy
Chuck
Thanks Chuck for your assistance here.
I wish i could see that, it locks the computer up before it gets to that point..
Perhaps because it is not gettitng any data back from the Netdurino.
Can you tell me the version of MFDeploy you have there, perhaps the version i have is bugged ????
I need to get this sorted out in case i need to return the Netdurino, i only got it 3 days ago.
Posted 07 July 2012 - 01:57 AM
Posted 07 July 2012 - 02:18 AM
Tree Frog,
MFDeploy hung on me the first time, but I had looked at several other things in configuration first. I unplugged and reconnected the USB. Pinged and then checked capabilities.
Attached in the about screen for MFDeploy.
Chuck
I tried it again a few times, then it worked, something not right there, needs looking at....
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
