Hi netduino wiki.
I have something to decompose in netduino plus.
With erase pin for logic high(3.3V) on power-up, my laptop doesn't talk netduino plus which was erased.
Device manager in laptop connected with netduino plus for but miscellaneous not usb of unknown device.
My tryings are below.
1. Wired with logic high in erase pin on power-up.
2. Connected the usb cable between laptop and netduino plus.
3. Check the device manager which showed that connecting with miscellaneous of unknown device.
4. There wasn't any progress on me after above.
5. No samba connection with RS232 or USB.
Thanks ahead.
The problem with earse pin in netduino plus
Started by yiulsup, May 29 2012 12:52 AM
6 replies to this topic
Posted 29 May 2012 - 12:52 AM
Posted 29 May 2012 - 02:36 AM
Hi yiulsup,
If you've erased your Netduino Plus using the gold ERASE pad, then you may need to specify the driver to install. Try to right-click on the device in Device Manager and select "install driver..."
The SAM-BA drivers are in the "C:\Program Files (x86)\ATMEL Corporation\sam-ba_2.11\drv" folder.
Posted 29 May 2012 - 04:48 AM
I tried with you mentioned above.
But there is useless for me to connect the netduino plus with my laptop.
Still unknown device in usb is on device manager.
Thanks ahead
Posted 29 May 2012 - 04:50 AM
My Windows is Windows 7, 64bit with Korean Edition of Ultimate
Posted 29 May 2012 - 05:13 AM
Hi yiulsup,
When you install the driver, follow these exact steps:
If this does not work, please take screenshots of each step so we can see what's going on on your computer. We're glad to help; we just need more information to know where you're getting stuck.
- Right-click on device in Device Manager
- Select "Install/Update Driver Software..."
- Click "Browse my computer for driver software."
- Click "Let me pick from a list of device drivers on my computer"
- Press "Have Disk..." If that is not available, select "All Devices" first.
- Browse to the SAM-BA drivers, then confirm.
Posted 29 May 2012 - 07:42 AM
I tried with above you adviced.
But my labtop doesn't talk to netduino plus with device manager which showed that device driver for netduino doesn't working with Exclamation mark named netduino.
I think there is something in .inf file for modifying and windows 7 with 64bit will be something in correction.
Thanks Chris.
Your time make me smile.
Posted 29 May 2012 - 11:55 AM
Have you tried plugging it in to a different USB port?
I sometimes have a similar issue with win 7 x64 where unless i change the physical port in use the netduino driver is loaded not the SAM-BA one.
Nak.
