Using TimeService
9 replies to this topic
#1 Szymon
Szymon
  • 108 posts
  • LocationPoland, Krakow
Posted 28 September 2010 - 07:24 AM
I'm trying to use the TimeService class (from Microsoft.SPOT.Time assembly) to synchronize time on Netduino with NTP server. Here is my code:
  var timeServer = "time.nist.org";
  IPHostEntry timeServerHostEntry = Dns.GetHostEntry(timeServer);
  var status = TimeService.UpdateNow(timeServerHostEntry.AddressList[0].GetAddressBytes(), 200);
  Debug.Print("Current time UTC"+status.CurrentTimeUTC);
But I get this exception when calling any method on TimeService:
    #### Exception System.NotSupportedException - CLR_E_NOT_SUPPORTED (1) ####
    #### Message:
    #### Microsoft.SPOT.Time.TimeService::UpdateNow [IP: 000a] ####
    #### NetworkTest.Program::Main [IP: 0044] ####
A first chance exception of type 'System.NotSupportedException' occurred in Microsoft.SPOT.Time.dll
An unhandled exception of type 'System.NotSupportedException' occurred in Microsoft.SPOT.Time.dll
Is this function implemented in Netduino Plus firmware?
#2 RvBCrS
RvBCrS
  • 31 posts
  • LocationZutphen, Netherlands
Posted 28 September 2010 - 08:04 AM
I don't know, don't have my Netduino Plus yet :( but maybe try the IP address of the NTP server, maybe DNS is not implemented yet, or what you said maybe NTP is not fully ready yet.
Blog: Morrison Blog
Twitter: @rvbcrs
#3 Szymon
Szymon
  • 108 posts
Posted 28 September 2010 - 08:09 AM
I have tried the same code with the Tahoe II board and in the emulator. Both work fine so I guess this is simply not implemented in the Netduino Plus firmware.
#4 Fred
Fred
  • 302 posts
  • LocationUK
Posted 28 September 2010 - 09:52 AM
I only got my ND+ this morning (and I'm at work so can't use it), but I'm pretty sure that DNS is not supported at the moment. Have you checked the IP you get before the TimeService call? Maybe it's not valid.
#5 Chris Walker
Posted 28 September 2010 - 01:34 PM
DNS is definitely supported in the Netduino Plus. The optional TimeService component is not included in the Netduino Plus firmware (to free more flash/RAM for apps)--but it would certainly be possible to add on such functionality... Chris
#6 Szymon
Szymon
  • 108 posts
Posted 28 September 2010 - 01:42 PM
Indeed DNS is supported and works fine for me.
I think for network connected data logger or similar web enabled scenario it would be beneficial to synchronize to proper local time. Even more because Netduino board doesn't include Real Time Clock so the time needs to be set after each reset.
Michael Schwarz shows how to query the NTP server in managed code and this doesn't look overly complex (I will try it today): http://weblogs.asp.n...rk-devices.aspx
If this is not adding much to the firmware size it would be good to have it implemented.
#7 Fred
Fred
  • 302 posts
  • LocationUK
Posted 28 September 2010 - 01:48 PM
Sorry! I'll keep quiet until I've actually used my Netduino Plus and know what I'm talking about. :)
#8 Szymon
Szymon
  • 108 posts
Posted 28 September 2010 - 01:50 PM
No worries. Maybe what you had in mind was using DHCP insteado of static IP configuration, which Chris warned that its not officially supported yet.
#9 Chris Walker
Posted 28 September 2010 - 02:13 PM
...DHCP insteado of static IP configuration, which Chris warned that its not officially supported yet.
[And on that, DHCP is actually fully implemented... But by using static IP, it's much easier to troubleshoot any glitches in lwIP: if something is not working properly, with static IP one at least knows that the Netduino Plus is already on the network :)]
#10 Moskus
Moskus
  • 132 posts
  • LocationNorway
Posted 13 September 2011 - 06:28 AM
Won't this solve the problem?
