Run Code From SD
Started by David Ditto, Mar 13 2012 06:25 PM
Posted 13 March 2012 - 06:25 PM
To Everyone,
I am a newbie to electronics and elementary at programming. I got my new Netduino Plus and I am wondering after "Hello World" if it is possible to request a health check from the Netduino and only Blink the LED if the Health Check is good.
I am also wondering if the program size limit imposed by the microcontrollers memory size can be extended by writing code both to the chip and an SD card. Would the Micro-controller be able to access the main program from memory and DLLs or Drivers from the SD card?
Just in case it helps to know the project that I am working, I am trying to program a telemetry type program that will first query all the chips to make sure they are healthy, and then query the chips to provide a GPS - Axis - Altitude report at Near Space altitudes.
Posted 13 March 2012 - 08:04 PM
As of now, it's not possible to write to flash from a program running on the Netduino. But there is talk of implementing this in future firmware releases.
See this thread where the topic is discussed further:
http://forums.netdui...o-flash-memory/
This is a sought for feature that would make it possible to save config data between power cycles.
Posted 13 March 2012 - 08:23 PM
Is this a good breakdown of what you're asking?
As for 2, there are a number of discussions on using the SD card as storage space for DLLs but keep in mind, once you load the DLL into memory, you're using the chip memory. You can't execute program space from the SD card directly. The SD card is primarily used to store log or resource files. I wouldn't count on being able to use this when decided on what boards to evaluate for your needs.
Side note: all consumer GPS receivers (sold in the US? made in the US? required by license?) have an arbitrary maximum operating altitude above which they will be unusable. Just something to be aware of when designing your project.
- Can you request a health check from the Netduino?
- Can you extend the program memory size by using an SD card?
Posted 13 March 2012 - 08:37 PM
"Side note: all consumer GPS receivers (sold in the US? made in the US? required by license?) have an arbitrary maximum operating altitude above which they will be unusable. Just something to be aware of when designing your project."
The DOD requiurement for the arbitrary maximum is 60K FT Altitude + 1K FtPS Speed. However most manufactures write the firmware code as 60K FT or 1 ftPS instead of 60KFT and 1 ftPS.
My team and I have posted emails to a few of the larger chip makers with what we are trying to do in an effort to get a properly coded GPS Chip that will meet our needs.
Posted 13 March 2012 - 08:40 PM
Sounds like you've got it covered then!
