Just got this 16x2 HD44780 controller from Hacktronics. After reading for a while, and realizing that using just the specified the Arduino wiring is not enough, I landed on Pete Brown's blog post.
I followed his instructions (almost) to the letter:
I soldered the head pins into place (been a while - man, I'm rusty)
I checked the continuity of my 16 pins
I connected all pins as specified in the post, using a mini breadboard, with the exception of Pin 3.
I do not have a potentiometer, so I just connected that pin to GND lcdPins.png20.82KB61 downloads
var lcdProvider = new GpioLcdTransferProvider(
Pins.GPIO_PIN_D12, // RS
Pins.GPIO_NONE, // RW
Pins.GPIO_PIN_D11, // enable
Pins.GPIO_PIN_D9, // d0
Pins.GPIO_PIN_D8, // d1
Pins.GPIO_PIN_D7, // d2
Pins.GPIO_PIN_D6, // d3
Pins.GPIO_PIN_D5, // d4
Pins.GPIO_PIN_D4, // d5
Pins.GPIO_PIN_D3, // d6
Pins.GPIO_PIN_D2); // d7
// create the LCD interface
var lcd = new Lcd(lcdProvider);
// set up the number of columns and rows:
lcd.Begin(16, 2);
// Print a message to the LCD.
lcd.Write("hello, world!");
// set the cursor to column 0, line 1
lcd.SetCursorPosition(0, 1);
// print the number of seconds since reset:
lcd.Write((Utility.GetMachineTime().Ticks / 10000).ToString());
Thread.Sleep(100);
What I got is an LCD in the "on" state showing one line of blocks and nothing I try get it to show anything. lcd.png1.65MB61 downloads
From this I deduce I must have been doing something right, to get the controller powered, but I must be missing something as well.
My only guesses are:
I screwed something up while soldering (although then I'd expect this to not work at all)
The potentiometer is a must for Pin 3 - skipping it might have done something
The list of connections Pete specified is not correct for my board/controller (I have an N+)
It is normal to see black blocks when the brightness regulation (i.e. the pot) is missing. By tying the brightness control to +5V, you won't see anything: it looks as powered off.
I don't think just only one resistor would be enough, because you should provide a certain voltage to that pin. I have used two resistors: the first is 680 Ohms to the ground, the second is 10KOhms to the +5V. In this way the voltage on the pin is: 5*680/(10K+680) = 0.32V
The Hitachi chip was very well designed. It manages always a 40x4 matrix (if I remember well), and the only difference is the LCD itself. If the display is limited to 16x2 chars, is only a problem of visibility area.
I used the off-display ram to store extra data.
A 1K pot is working good as well, but it makes flowing a current 10x uselessly. The ideal is a 50K pot.
I am having difficulty connecting the LCD through a 74HC595 ...
Problem solved ... usb froze and the potentiometer I was using was too strong ... lol cool !
Started with C in 1985, moved to Vb3 ... to vb6 and stopped. Now started with .Net and learning C# and VB.net and wishing VB.net was on MF !
Thanks for all the replies, and I'll go out and get a 10k pot + a bunch of resistors later today.
But I still do have a question: if this has something to do with the brightness (lack of resistance on Pin 3), shouldn't I be seeing 2 lines of blocks rather than one? Will adding resistance solve the problem, or just move me to the next one?
My circuit using a 16x2 display is still working on my breadboard.
I used the 74HC595 and the SPI because it took only three ports.
Anyway, the only "problem" I had was just the brightness: at the very first the circuit seems not working, then by adjusting the pot magically the "Hello world" appeared!
I wouldn't worried about the one-line-of-blocks: just add the pot, then we will talk about.
SOLVED!
Well, what do you know? It was my $#itty soldering after all!
After racking my brain, re-wiring the LCD, checking each line of code and visiting tons of blogs (thank you all),
I finally went back to basics: I bought a real soldering station and got rid of the Fry
s $10 house burner. I also got a nice solder sucker.
I de-soldered all my connections, re-soldered them at 700F, re-wired one last time, and presto! It works. Attached image proof
