Netduino firmware with GCC 4.4
Posted 21 August 2010 - 03:16 PM
- ahmad22as likes this
Posted 21 August 2010 - 05:54 PM
Posted 22 August 2010 - 06:12 PM
Very handy indeed, works like a charm. ThanksAttached is a zip file that contains an updated build environment to allow the use of GCC 4.4 to build the firmware.
The following flash sector map configuration (in Netduino solution DeviceCode\Blockstorage\Sam7X_blockstorage\Sam7x_Bl_Config.cpp) compiled with GCC 4.4 creates a bootloader that is able to successfully deploy the firmware (default features selected):This yields a much smaller binary than the 4.2 build tools. This saves around 15K or so with the stock netduino formware build.
const BlockRange g_SAM7X_BS_BlockRange[] = { { BlockRange::BLOCKTYPE_BOOTSTRAP, 0, 5 }, // 0xC000 { MEMORY_BLOCKTYPE_GCC_SPECIAL_BOOTSTRAP, 6, 10 }, // 0xA000, Sum = 0x16000 (.bin size = 0x143B0) { BlockRange::BLOCKTYPE_CODE, 11, 44 }, // 0x4400 { MEMORY_BLOCKTYPE_GCC_SPECIAL_CODE, 45, 53 }, // 0x12000, Sum = 0x56000, Flash size = 0x542C0 { BlockRange::BLOCKTYPE_DEPLOYMENT, 54, 60 }, // 0xE000 -> 56 KiBi for application code { BlockRange::BLOCKTYPE_STORAGE_A, 61, 61 }, { BlockRange::BLOCKTYPE_STORAGE_B, 62, 62 }, { BlockRange::BLOCKTYPE_CONFIG, 63, 63 }};Note: Blocks of same type can be merged (bootstrap + GCC special bootstrap, Code + GCC special code), they are there to enable compile-time configuration for GCC vs. the other compilers.
However, during my numerous experiments, I have found out that bootloader compiled with RVDS actually works with firmware compiled with GCC 4.4 (!), so it appears to be a better choice, as there is more memory left for the application code, because GCC bootloader is twice as big as RVDS one (~40 KiBi vs. ~80 KiBi). I will probably stick with this for now...
Posted 22 August 2010 - 09:19 PM
This is fantastic, jeremy. Would it be alright if we integrated this into the Netduino source code download (or at least put a link to it in the downloads section)?
I would be honored if you did either of those things. It's nice to give back for a change.
Jeremy.
Posted 31 August 2010 - 05:38 PM
I used your patches and all works pretty much as expected. Just to confirm, the target firmware will still be too large and will require the fix mentioned
I get:
c:\GCC\bin\arm-none-eabi-ld.exe: region `LR_FLASH' overflowed by 576 bytes
Does this match your build? If so, its a pity its such a small difference!
edit: CW2:
For clarity (on my part):
// flash page is 8KB // ranges are inclusive i.e. 0-5 is 6 pages const BlockRange g_SAM7X_BS_BlockRange[] = { { BlockRange::BLOCKTYPE_BOOTSTRAP, 0, 5 }, // 0x00000 - ( 6*8*1024) 0x0C000, length 0x0C000 { MEMORY_BLOCKTYPE_GCC_SPECIAL_BOOTSTRAP, 6, 10 }, // 0x0C000 - (11*8*1024) 0x16000, length 0x0A000, Sum = 0x16000 (.bin size = 0x143B0) { BlockRange::BLOCKTYPE_CODE, 11, 44 }, // 0x16000 - (45*8*1024) 0x5A000, length 0x44000 { MEMORY_BLOCKTYPE_GCC_SPECIAL_CODE, 45, 53 }, // 0x5A000 - (54*8*1024) 0x6C000, length 0x12000, Sum = 0x56000, Flash size = 0x542C0 { BlockRange::BLOCKTYPE_DEPLOYMENT, 54, 60 }, // 0x6C000 - (61*8*1024) 0x7A000, length 0x0E000 -> 56 KiBi for application code { BlockRange::BLOCKTYPE_STORAGE_A, 61, 61 }, // 0x7A000 - (62*8*1024) 0x7C000, length 0x02000 { BlockRange::BLOCKTYPE_STORAGE_B, 62, 62 }, // 0x7C000 - (63*8*1024) 0x7E000, length 0x02000 { BlockRange::BLOCKTYPE_CONFIG, 63, 63 } // 0x7E000 - (64*8*1024) 0x80000, length 0x02000 };
So therefore:
<Set Name="Code_BaseAddress" Value="0x00116000"/> <Set Name="Deploy_BaseAddress" Value="0x0016C000"/>
And once I have this correct I should be able to flash?
also:
This would be nice any hints on how to accomplish it?
-(e)
Posted 01 September 2010 - 09:22 AM
Posted 01 September 2010 - 09:45 AM
I hope so, I used the same values.And once I have this correct I should be able to flash?
Modify the block range table (conditional compilation symbols) so it contains the first 0xC000 bootstrap block, and the rest leave for code. Compile with RVDS, flash TinyBooterDecompressor.bin using SAM-BA (the bootloader now has block range table with code blocks large enough to contain firmware compiled with GCC), then compile firmware with GCC 4.4 and deploy ER_FLASH, ER_CONFIG via MFDeploy.This would be nice any hints on how to accomplish it?
Tip: It is also possible to deploy bootloader hex files via MFDeploy, as long as the code fits into block range sectors.
EDIT: To verify block range table contents you can use "Flash Sector Map" command in MFDeploy's Plug-in\Debug menu.
Edited by CW2, 01 September 2010 - 09:53 AM.
Posted 16 October 2010 - 08:30 AM
Here's what I've installed so far:
- Installed Visual C# Express 2010 and Visual C++ Express 2010
- Installed MicroFrameworkPK, MicroFrameworkPK (ARM Network Pack), MicroFrameworkPK (Crypto Pack) into MicroFrameworkPK_v4_1 folder
- Installed code sourcery arm-2010q1-188-arm-none-eabi downloaded from here http://www.codesourc...tal/release1294
- Copied Netduino Firmware v4.1.0 (patch 2) into the MicroFrameworkPK_v4_1 folder
- Download, unzipped the attachment from this thread and copied files into MicroFrameworkPK_v4_1 folder
At the command prompt:
- cd \MicroFrameworkPK_v4_1
- setenv_gcc4.4 c:\CodeSourcery
- msbuild Solutions\Netduino\dotnetemf.proj /p:flavor=release
Here's the error:
[code=auto:0]"C:\MicroFrameworkPK_v4_1\Solutions\Netduino\dotnetmf.proj" (default target) (1
"C:\MicroFrameworkPK_v4_1\Solutions\Netduino\TinyCLR\TinyCLR.proj" (Build targe
t) (84) ->
(BuildAXF target) ->
C:\MicroFrameworkPK_v4_1\tools\targets\Microsoft.SPOT.System.GCC.targets(343,
5): error MSB3073: The command ""c:\CodeSourcery\bin\arm-none-eabi-ld.exe" -st
atic --gc-sections --no-warn-mismatch --library-path=C:\MicroFrameworkPK_v4_1\B
uildOutput\THUMB\GCC4.4\le\FLASH\release\Netduino\lib --library-path=C:\MicroFr
ameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib --allow-mult
iple-definition -u ARM_Vectors -u _start --Map C:\MicroFrameworkPK_v4_1\BuildOu
tput\THUMB\GCC4.4\le\FLASH\release\Netduino\bin\tinyclr.map --output=C:\MicroFr
ameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\FLASH\release\Netduino\bin\tinyclr.a
xf --script=C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\FLASH\release\
Netduino\bin\tinyclr_scatterfile.ldf C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB
\GCC4.4\le\FLASH\release\Netduino\obj\Solutions\Netduino\TinyCLR\tinyclr_dat.ob
j C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\FLASH\release\Netduino\o
bj\Solutions\Netduino\TinyCLR\allocator.obj C:\MicroFrameworkPK_v4_1\BuildOutpu
t\THUMB\GCC4.4\le\FLASH\release\Netduino\obj\Solutions\Netduino\TinyCLR\tinyclr
.obj -( C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\
lib\Core.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\rel
ease\lib\Hardware.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_
MEDIA\release\lib\InterruptHandler.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THU
MB\GCC4.4\le\ANY_MEDIA\release\lib\I2C.lib C:\MicroFrameworkPK_v4_1\BuildOutput
\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\IOPort.lib C:\MicroFrameworkPK_v4_1\Buil
dOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\RPC_stub.lib C:\MicroFrameworkPK_
v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\Serialization_stub.lib C
:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\Debug
ger.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\
lib\Debugger_full.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_
MEDIA\release\lib\Graphics_stub.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\
GCC4.4\le\ANY_MEDIA\release\lib\CorLib.lib C:\MicroFrameworkPK_v4_1\BuildOutput
\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\SPOT.lib C:\MicroFrameworkPK_v4_1\BuildO
utput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\SPOT_Crypto_stub.lib C:\MicroFramew
orkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\SPOT_Messaging_stu
b.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\li
b\SPOT_Serialization_stub.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4
\le\ANY_MEDIA\release\lib\SPOT_Hardware.lib C:\MicroFrameworkPK_v4_1\BuildOutpu
t\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\Messaging.lib C:\MicroFrameworkPK_v4_1\
BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\CLRStartup.lib C:\MicroFramew
orkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\CRC.lib C:\MicroFr
ameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\WireProtocol.l
ib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\S
POT_Hardware_SerialPort.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\l
e\ANY_MEDIA\release\lib\HeapPersistence.lib C:\MicroFrameworkPK_v4_1\BuildOutpu
t\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\Diagnostics.lib C:\MicroFrameworkPK_v4_
1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\Stream.lib C:\MicroFramewor
kPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\SPOT_IO.lib C:\Micro
FrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\ANY_MEDIA\release\lib\SPOT_Hardwar
e_Usb.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\FLASH\release\Ne
tduino\lib\tmp_tinyclr.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le
\FLASH\release\Netduino\lib\InteropAssembliesTable.lib -) -( "c:\CodeSourcery\a
rm-none-eabi\lib\thumb\libm.a" "c:\CodeSourcery\arm-none-eabi\lib\thumb\libc.a"
"c:\CodeSourcery\lib\gcc\arm-none-eabi\4.4.1\thumb\libgcc.a" -) -( C:\MicroFra
meworkPK_v4_1\tools\ads_v3_1\Lib\armlib\h_t.l C:\MicroFrameworkPK_v4_1\tools\ad
s_v3_1\Lib\armlib\c_t.l -)" exited with code 1. [C:\MicroFrameworkPK_v4_1\Solut
ions\Netduino\TinyCLR\TinyCLR.proj[code=auto:0]
Any ideas?
Posted 16 October 2010 - 01:17 PM
There is C:\PCodeSourcery (extra 'P') in the error dump.- setenv_gcc4.4 c:\CodeSourcery
Posted 16 October 2010 - 02:07 PM
Posted 16 October 2010 - 07:11 PM
"C:\MicroFrameworkPK_v4_1\Solutions\Netduino\TinyCLR\TinyCLR.proj" (default tar get) (1) -> (BuildAXF target) -> C:\MicroFrameworkPK_v4_1\tools\targets\Microsoft.SPOT.System.GCC.targets(306, 5): error MSB3073: The command ""c:\CodeSourcery\4.2\bin\arm-none-eabi-ld.exe" -static --gc-sections --no-warn-mismatch --library-path=C:\MicroFrameworkPK_v4 _1\BuildOutput\THUMB\GCC4.2\le\FLASH\release\Netduino\lib --library-path=C:\Mic roFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib --allow- multiple-definition -u ARM_Vectors -u _start --Map C:\MicroFrameworkPK_v4_1\Bui ldOutput\THUMB\GCC4.2\le\FLASH\release\Netduino\bin\tinyclr.map --output=C:\Mic roFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\FLASH\release\Netduino\bin\tinyc lr.axf --script=C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\FLASH\rele ase\Netduino\bin\tinyclr_scatterfile.ldf C:\MicroFrameworkPK_v4_1\BuildOutput\T HUMB\GCC4.2\le\FLASH\release\Netduino\obj\Solutions\Netduino\TinyCLR\tinyclr_da t.obj C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\FLASH\release\Netdui no\obj\Solutions\Netduino\TinyCLR\allocator.obj C:\MicroFrameworkPK_v4_1\BuildO utput\THUMB\GCC4.2\le\FLASH\release\Netduino\obj\Solutions\Netduino\TinyCLR\tin yclr.obj -( C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\rele ase\lib\Core.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA \release\lib\Hardware.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ ANY_MEDIA\release\lib\InterruptHandler.lib C:\MicroFrameworkPK_v4_1\BuildOutput \THUMB\GCC4.2\le\ANY_MEDIA\release\lib\I2C.lib C:\MicroFrameworkPK_v4_1\BuildOu tput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\IOPort.lib C:\MicroFrameworkPK_v4_1\ BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\RPC_stub.lib C:\MicroFramewor kPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\Serialization_stub.l ib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\D ebugger.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\rele ase\lib\Debugger_full.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ ANY_MEDIA\release\lib\Graphics_stub.lib C:\MicroFrameworkPK_v4_1\BuildOutput\TH UMB\GCC4.2\le\ANY_MEDIA\release\lib\CorLib.lib C:\MicroFrameworkPK_v4_1\BuildOu tput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\SPOT.lib C:\MicroFrameworkPK_v4_1\Bu ildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\SPOT_Crypto_stub.lib C:\MicroFr ameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\SPOT_Messaging _stub.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\releas e\lib\SPOT_Serialization_stub.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GC C4.2\le\ANY_MEDIA\release\lib\SPOT_Hardware.lib C:\MicroFrameworkPK_v4_1\BuildO utput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\Messaging.lib C:\MicroFrameworkPK_v 4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\CLRStartup.lib C:\MicroFr ameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\CRC.lib C:\Mic roFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\WireProtoc ol.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\l ib\SPOT_Hardware_SerialPort.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4 .2\le\ANY_MEDIA\release\lib\HeapPersistence.lib C:\MicroFrameworkPK_v4_1\BuildO utput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\Diagnostics.lib C:\MicroFrameworkPK _v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\Stream.lib C:\MicroFram eworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\SPOT_IO.lib C:\M icroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\ANY_MEDIA\release\lib\SPOT_Har dware_Usb.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le\FLASH\releas e\Netduino\lib\tmp_tinyclr.lib C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4. 2\le\FLASH\release\Netduino\lib\InteropAssembliesTable.lib -) -( "c:\CodeSource ry\4.2\arm-none-eabi\lib\thumb\libm.a" "c:\CodeSourcery\4.2\arm-none-eabi\lib\t humb\libc.a" "c:\CodeSourcery\4.2\lib\gcc\arm-none-eabi\4.2.1\thumb\libgcc.a" - ) -( C:\MicroFrameworkPK_v4_1\tools\ads_v3_1\Lib\armlib\h_t.l C:\MicroFramework PK_v4_1\tools\ads_v3_1\Lib\armlib\c_t.l -)" exited with code 1. [C:\MicroFramew orkPK_v4_1\Solutions\Netduino\TinyCLR\TinyCLR.proj]
Edit:
The reported error in C:\MicroFrameworkPK_v4_1\tools\targets\Microsoft.SPOT.System.GCC.targets on line 306 is this:
<Exec Condition="'$(COMPILER_TOOL_VERSION)'=='GCC4.2'" Command="$(LINK) $(LINK_FLAGS) -u ARM_Vectors -u _start --Map $(EXEName).map --output=@(EXEOutput) --script=@(EXEScatterFile,' ') @(EXEInputs,' ') -( @(PlatformIndependentLibs-> '$(PLATFORM_INDEPENDENT_RELATIVE_LIB_DIR)%(FileName)%(Extension)',' ') $(LIB_DIR)\tmp_$(AssemblyName).$(LIB_EXT) @(InputLibs,' ') -) -( "$(GNU_LIB_DIR)\libm.a" "$(GNU_LIB_DIR)\libc.a" "$(GNU_LIBGCC_DIR)\$(LIBGCC)" -) -( $(ExtraLibs) - )"/>
Edit:
Finally got this to compile - so I thought I'd add it here to help all the newbies like me. Here's what I did.
1. Installed Porting Kit NoLibs and Porting Kit NetARM (did not install Porting Kit Crypto Pack)
2. Run the build and send the output to a file, eg:
msbuild Solutions\Netduino\dotnetmf.proj /t:build /t:flavor=release > log.txt
3. Open log.txt and copy the command which is causing the error, eg:
The command ".....copy everything between these quotes....." exited with code 1. [C:\MicroFramew orkPK_v4_1\Solutions\Netduino\TinyCLR\TinyCLR.proj]
4. Paste the command into the command prompt and hit enter - it runs and shows a different error message, one that you can actually read, eg:
c:\CodeSourcery\bin\arm-none-eabi-ld.exe: C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.2\le \FLASH\release\Netduino\bin\tinyclr.axf section ER_FLASH will not fit in region LR_FLASH c:\CodeSourcery\bin\arm-none-eabi-ld.exe: region LR_FLASH overflowed by 15744 bytes
5. From there it's pretty easy. In this case the solution is to adjust the memory which is described here.
6. Profit!
I'm going to try the same approach with GCC4.4 and see if I can get that to work.
Edit:
Making progress - build.dirproj builds without errors using GCC 4.4, however building the Netduino solution results in this error:
tmp_Tinybooter.lib(tinyhal.obj): In function `HAL_Initialize()': tinyhal.cpp:(.text._Z14HAL_Initializev+0x104): undefined reference to `DeploymentTransport_Initialize()'
Edited by dragonfly, 18 November 2010 - 08:57 PM.
Posted 18 November 2010 - 08:56 PM
<Set Name="Deploy_BaseAddress" Value="0x00172348"/>
Compiling now gives a generic CLR_E_FAIL error for metadataprocessor for this command:
C:\MicroFrameworkPK_v4_1\BuildOutput\public\Release\Server\dll\MetaDataProcessor.exe -sign_file C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\FLASH\release\Netduino\bin\tinyclr.bin\ER_DAT C:\MicroFrameworkPK_v4_1\tools\bin\tinybooter_private_key.bin C:\MicroFrameworkPK_v4_1\BuildOutput\THUMB\GCC4.4\le\FLASH\release\Netduino\bin\tinyclr.hex\ER_DAT.sig
... yet crazy-land does not end there, oh no. In trying to replicate everything I deleted the BuildOutput folder, then did:
msbuild /t:clean build.dirproj msbuild /t:build build.dirproj
The result, 442 Error(s). Meh, enough to make one crazy
I've attached the current firmware which I'm trying to build.
Edit:
GCC 4.4 compiles now for fw 4.1.0.5 - I have posted the patch on the thread for that firmware.
Posted 02 June 2011 - 01:18 PM
Attached is a zip file that contains an updated build environment to allow the use of GCC 4.4 to build the firmware. This yields a much smaller binary than the 4.2 build tools. This saves around 15K or so with the stock netduino formware build.
The build environment is copied over the existing files in the same way the original netduino firmware source is deployed.
A new setenv command, setenv_gcc4.4 is used to set the build environment up. This is used the same way as the original setenv_gcc command.
Does it work for ND+ too if I copy files in right location ?
Posted 03 June 2011 - 08:16 AM
Edit:
How did you managed to get thru it ? is it a matter of FW version ?
