OutOfMemory not expected
#1 Nicolas Dorier
Nicolas Dorier
  • 24 posts
Posted 04 March 2011 - 08:37 AM
Hi, here is a really simple program :
ArrayList list = new ArrayList();
			for(int i = 0; i < 1000; i++)
				list.Add(i);
				Log(i.ToString() + " " + Debug.GC(true).ToString());
And it seems that an OutOfMemoryException is raised very early... After 473 elements... and 14844 Bytes unused in the RAM
469 14940
470 14916
471 14892
472 14868
473 14844
#### Exception System.OutOfMemoryException - CLR_E_OUT_OF_MEMORY (1) ####
What is going on ?
Posted 04 March 2011 - 10:29 AM
Hi Nicolas, I haven't looked at how ArrayList is built internally, but is it possible that it's creating a new ArrayList pointer set every time you add an element to the list? [In other words, it would need to have 1x the size of the list available at all times.] I'm assuming that it's not implemented that way...but it might be. Do you get the error consistently after the same number of iterations? Could you please post a sample of your actual test project...and we can test it out here as well? Thanks! Chris
#3 Nicolas Dorier
Nicolas Dorier
  • 24 posts
Posted 04 March 2011 - 09:18 PM
Yes the error comes consistently. I have also tried to create several big byte array and it does not work even if it seems I have enough space. I can create 20 byte array of 512 element, but cannont create 1 byte array of 10 000. My guess is that internally, for the ArrayList and Array, the .NET try to get continuous memory blocks. Depending on the internal implementation of ArrayList, maybe after 473 elements, it tries to expand to a bigger array at twice as big as the source array of 473 elements. (and it seems that each elements takes 24 bytes) I send you all there different use case and the results I get with my netduino tomorrow.
#4 Nicolas Dorier
Nicolas Dorier
  • 24 posts
Posted 05 March 2011 - 03:02 PM
Here is the solution, my netduino is v 4.1.1.7a
#5 Corey Kosak
Corey Kosak
  • 276 posts
  • LocationHoboken, NJ
Posted 07 March 2011 - 01:55 AM
I feel your pain. We discussed this issue in depth on the first page of this topic.
Regarding your failure to create a 10000 element array, I've also seen that happen. I don't have a solid explanation yet in that case but I've been meaning to figure it out one of these days.
#6 Earthed
Earthed
  • 20 posts
  • LocationAustralia
Posted 30 August 2011 - 12:44 PM
I have had an interesting issue arrise and not cause an exception immediately upon calling: char[] chars = new char[mBufferMax]; //where mBufferMax=500, chars[128] was created, not chars[500]! very shortly after I got a CLR_E_OUT_OF_MEMORY (1) PS: Whats the difference between the following? CLR_E_OUT_OF_MEMORY (1) CLR_E_OUT_OF_MEMORY (3)
