![Photo](http://forums.netduino.com/uploads/profile/photo-thumb-2260.png?_r=0)
Error: No response from device (HELP!!!)
Posted 02 March 2011 - 07:50 PM
Posted 03 March 2011 - 02:51 AM
Posted 04 March 2011 - 10:03 PM
Hi Black Rose,
When you power on your Netduino Plus, does the blue LED go out after a few seconds (indicating that it has booted)?
If so, try to erase your current Netduino app:
1. Unplug your Netduino Plus and all components
2. Open up MFDeploy on your computer, select USB transport
3. Hold down the pushbutton on your Netduino Plus. This will force it into bootloader mode.
4. Connect your Netduino Plus to your PC (and keep holding the button).
5. Within 2 seconds, press the ERASE button in MFDeploy.
Does that fix things for you?
Also...after that, I'd recommend upgrading to the lasest firmware (v4.1.0.6 or v4.1.1 alpha 7+).
Thanks it works (:
Posted 08 March 2013 - 02:04 AM
Hi Black Rose, When you power on your Netduino Plus, does the blue LED go out after a few seconds (indicating that it has booted)? If so, try to erase your current Netduino app: 1. Unplug your Netduino Plus and all components 2. Open up MFDeploy on your computer, select USB transport 3. Hold down the pushbutton on your Netduino Plus. This will force it into bootloader mode. 4. Connect your Netduino Plus to your PC (and keep holding the button). 5. Within 2 seconds, press the ERASE button in MFDeploy. Does that fix things for you? Also...after that, I'd recommend upgrading to the lasest firmware (v4.1.0.6 or v4.1.1 alpha 7+). Chris
I have the same problem too, after ive upgraded the firmware to 4.2,2. But when plugged into the USB, the LED is not blinking. However there is an error message saying that "There were deployment error. Continue?" and error output message " Unable to communicate with device - USB:Netduino"..
I encountered this problem before. The first was i need to change the hardware. So,i am afraid if the problem i faced is similar like before.
Your help is kindly appreciated!
Posted 08 March 2013 - 06:01 AM
Posted 08 March 2013 - 07:27 AM
I managed to solve the problem. Yup,thanks for the help Chris!
