2 projects, 1 works, 1 gives hardware error
#1 onedumbtrucker
onedumbtrucker
  • 13 posts
Posted 02 June 2016 - 07:06 PM
Hey all,
Wondering if anyone has any ideas about this. I have two different projects, both created for the Netduino3 Ethernet.
One is a simple blinking light for testing hardware and I can deploy and run it fine.
The other is the actual application I am developing and it worked the first couple times after I created it. (copied source code from an ND+ project). But now for some reason everytime I try to deploy I get the following message.
"Error 1 An error has occurred: please check your hardware. "
But if I switch over to my blinking light project I can deploy it fine.
One thing to note, I found I have to use the firmware updater tool to erase the application from the ND3E to switch projects. But that doesn't explain why one works and one doesn't.
I may try building the project from scratch again.
The only other difference I can see is that I included a reference to System.IO in the project that doesn't work.
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 03 June 2016 - 05:50 AM
Sounds like you might have inconsistent firmware versions.  Check that both projects reference the same version of the NETMF.
#3 onedumbtrucker
onedumbtrucker
  • 13 posts
Posted 13 June 2016 - 10:16 PM
They do.
#4 HiredMind
HiredMind
  • 25 posts
Posted 28 June 2016 - 02:18 AM
Look in the Visual Studio output window. There might be more detail there. Sometimes the detail is useful in and of itself, sometimes it's only useful as a means of providing a better error message to search for.
Main pull-down menu bar:
Debug -> Windows -> Output
