Odd compilation and deployment problems in VS2015
visual-studio-2015 compilation deployment errors
7 replies to this topic
#1 NameOfTheDragon
NameOfTheDragon
  • 112 posts
  • LocationCanterbury, Kent, UK
Posted 10 September 2015 - 05:21 PM
Hey everyone, has anyone been successful with Visual Studio 2015?
I've recently upgraded and I'm having some issues. I've installed the project system for VS2015 and when I compile my code, I've started getting this error:
CS1579 foreach statement cannot operate on variables of type 'string' because 'string' does not contain a public definition for 'GetEnumerator'
Well, the error message seems to be accurate, but this code used to compile and run correctly under VS2013. Did something change? I have quite a few projects that use this idiom to iterate through the characters in a string. I can change them, no big deal, but I'd rather not have to, really.
But the real showstopper is a problem I'm having during deployment (after I fix CS1579):
resolving
Resolve: unknown type: System.Diagnostics.DebuggerBrowsableState
Error: ff000000
Any clues, anyone?
#2 Juzzer
Juzzer
  • 135 posts
  • LocationHertfordshire, UK
Posted 11 September 2015 - 03:19 AM
https://www.ghielect...d=19617&page=1?
#3 NameOfTheDragon
NameOfTheDragon
  • 112 posts
Posted 11 September 2015 - 03:28 AM
Thanks for responding, but the link doesn't seem to work: "No such page exists"
#4 NameOfTheDragon
NameOfTheDragon
  • 112 posts
Posted 11 September 2015 - 03:46 AM
Oh wait, I found it... I'm supposed to add the following to my code:
namespace System.Diagnostics
    public enum DebuggerBrowsableState
        Never,
        Collapsed,
        RootHidden
#5 Tom
Tom
  • 7 posts
Posted 11 September 2015 - 07:11 AM
Yep, have also ran into that annoying problem. Adding that enum in manually seems to be the only fix available.
I'm assuming it's a new(-ish) compiler added attribute that's not in the base netmf core lib.
#6 NameOfTheDragon
NameOfTheDragon
  • 112 posts
Posted 11 September 2015 - 02:45 PM
Well, it's not a total fix. I added it to a library project and the library project then worked. However the next project I tried, which consumes that library and so should have visibility of the attribute, which is public, suffered from the same problem.
Now, even if I add the enum directly into my application, I still get the 'resolving' error on deployment. It is broke, broke, broke. Showstopper! I've had to switch back to VS2013, which luckily I hadn't uninstalled, and everything is fine again.
I think SecretLabs should raise this directly with the NetMF team at Microsoft... you have a lot more clout than we as individual developers.
#7 Juzzer
Juzzer
  • 135 posts
Posted 11 September 2015 - 10:57 PM
It's already been raised with the NETMF team.
#8 HiredMind
HiredMind
  • 25 posts
Posted 19 June 2016 - 08:39 PM
FYI: Adding that enum code to each assembly (both the main executable, and every library) seems to work.
