Looking for a device on transport 'USB'Starting device deployment...Iteration 0Opening port \\?\USB#VID_22B1&PID_1000#000000000000#{09343630-a794-10ef-334f-82ea332c49f3}\OperationsAttaching debugger engine...... debugger engine attached!Querying device assemblies...Found Assembly mscorlib 4.3.1.0Found Assembly Microsoft.SPOT.Native 4.3.1.0Found Assembly Microsoft.SPOT.Hardware 4.3.1.0Found Assembly Microsoft.SPOT.Hardware.SerialPort 4.3.1.0Found Assembly Microsoft.SPOT.IO 4.3.1.0Found Assembly System.IO 4.3.1.0Found Assembly Microsoft.SPOT.Hardware.PWM 4.3.1.0Found Assembly Microsoft.SPOT.Hardware.Usb 4.3.1.0Found Assembly SecretLabs.NETMF.Diagnostics 4.3.1.0Found Assembly GoBus 1.5.0.0Found Assembly SecretLabs.NETMF.Hardware.Netduino 4.3.1.0Found Assembly SecretLabs.NETMF.IO 4.3.1.0Found Assembly Microsoft.SPOT.Hardware.OneWire 4.3.1.0Found Assembly System 4.3.1.0Found Assembly SecretLabs.NETMF.Hardware 4.3.1.0Found Assembly NetduinoApplication7 1.0.0.0Found Assembly Microsoft.SPOT.Net 4.3.1.0Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.pe to deployment bundleAdding pe file C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\secretlabs.netmf.hardware.pe to deployment bundleAdding pe file C:\Users\Chad\Documents\Netduino\Projects\NetduinoApplication7\NetduinoApplication7\bin\Debug\le\NetduinoApplication7.pe to deployment bundleAdding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.pe to deployment bundleAttempting deployment...Incrementally deploying assemblies to deviceAll assemblies on the device are up to date. No assembly deployment was necessary.Assemblies successfully deployed to device.Restarting interpreter...Attaching to device...Waiting for device to initialize...
This is as far as I get when trying to debug. Then I hear the USB device sound toggle 3-4 times and then it looks like visual studio gives up.
Things I've tried:
- erasing the board with Netduino Update
- re-updating firmware with Netduino Update
- restarting Visual Studio
- Rebooting Computer
- trying different USB port on my computer
Any other ideas?
