I think I might know what is going on. My SDK installed on my PC seems like v 4.1 as per the deployment:
Found debugger!
Found debugger!
Create TS.
Loading start at 8065cf4, end 808ce94
Assembly: mscorlib (4.3.1.0)
Assembly: Microsoft.SPOT.Native (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Net (4.3.1.0)
Assembly: Microsoft.SPOT.Net.Security (4.3.1.0)
Assembly: System (4.3.1.0)
Assembly: System.Net.Security (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0)
Assembly: System.IO (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Netduino.IP (1.0.0.0)
Assembly: Netduino.IP.Interop (1.0.0.0)
Assembly: Netduino.IP.LinkLayers.CC3100 (1.0.0.0)
Assembly: SecretLabs.NETMF.Diagnostics (4.3.1.0)
Assembly: GoBus (1.5.0.0)
Assembly: SecretLabs.NETMF.Hardware.Netduino (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.OneWire (4.3.1.0)
Loading Deployment Assemblies.
Attaching deployed file.
Assembly: NetduinoApplication2 (1.0.0.0)
Assembly: SecretLabs.NETMF.IO (4.3.1.0)
Assembly: NetDuino.Domain (1.0.0.0)
Assembly: SecretLabs.NETMF.Hardware (4.3.1.0)
Resolving.
The debugging target runtime is loading the application assemblies and starting execution.
Ready.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.Security.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Net.Security.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll', Symbols loaded.
Invalid address 0 and range 40 Ram Start 20000000, Ram end 20030000
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
Invalid address 1000fbb4 and range 4 Ram Start 20000000, Ram end 20030000
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'Netduino.IP'
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'Netduino.IP.Interop'
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'Netduino.IP.LinkLayers.CC3100'
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\SecretLabs.NETMF.Diagnostics.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\GoBus.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\SecretLabs.NETMF.Hardware.Netduino.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\_Dev\LiquidataFlow\trunk\Src\NetDuino\NetDuino.Domain\bin\Debug\le\NetDuino.Domain.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'D:\Temp\NetduinoApplication2\NetduinoApplication2\bin\Debug\le\NetduinoApplication2.exe', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\SecretLabs.NETMF.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\SecretLabs.NETMF.Hardware.dll', Symbols loaded.
The thread '<No Name>' (0x2) has exited with code 0 (0x0).
A first chance exception of type 'System.Exception' occurred in Microsoft.SPOT.Hardware.dll
The program '[13] Micro Framework application: Managed' has exited with code 0 (0x0).
But my device has this on:
Connecting to Netduino3_Netduino...Connected
HalSystemInfo.halVersion: 4.3.1.0
HalSystemInfo.halVendorInfo: Netduino 3 Wi-Fi (v4.3.2.1) by Secret Labs LLC
HalSystemInfo.oemCode: 34
HalSystemInfo.modelCode: 177
HalSystemInfo.skuCode: 4105
HalSystemInfo.moduleSerialNumber: 00000000000000000000000000000000
HalSystemInfo.systemSerialNumber: 0000000000000000
ClrInfo.clrVersion: 4.3.1.0
ClrInfo.clrVendorInfo: Netduino 3 Wi-Fi (v4.3.2.1) by Secret Labs LLC
ClrInfo.targetFrameworkVersion: 4.3.1.0
SolutionReleaseInfo.solutionVersion: 4.3.2.1
SolutionReleaseInfo.solutionVendorInfo: Netduino 3 Wi-Fi (v4.3.2.1) by Secret Labs LLC
SoftwareVersion.BuildDate: May 8 2015
SoftwareVersion.CompilerVersion: 410894
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 0
LCD.Height: 0
LCD.BitsPerPixel: 0
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: False
Profiling: False
ProfilingAllocations: False
ProfilingCalls: False
IsUnknown: False
I uninstalled everything and then followed the download links and updated my Firmware using the tool to update.
Seems like this error occur at a fixed time interval and must be some background thread. I have only been developing for around 2 months...so please tell me if I am doing something wrong here.
One more thing....I did exactly the same the the netduino plus 2 (upgrading) but it runs fine. Very Weird....
Riaan
