I am unable to deploy my application using Visual Studio 2012. I have three Netduino Plus 2 boards and all three act the same. I can connect, erase, network configure, and display device capibilities using MFdeploy. I can upgrade the boards to 4.3.1 using the NetduinoUpgrade program.
However when I try to deploy using VS2012, I am unable. The error message is: 'unable to communicate with device:USB:Netduino"
If I hit F5 while the USB cable is unplugged, and then plug it in, I seem to get further, I get a message that the debugger has been found, but the after a delay, it says "cannot attach debugger engine".
I used this same PC and setup to deploy the same application a couple of weeks ago with no problems, so I am puzzled why it no longer works, and not sure how to fix the problem. I see other threads on similar issues, but the most recent one has no posted solution.
I have a customer order that I cannot ship until this is fixed. Is there a way to get VS 2012 to create a file (like a hex file for example) such that MFdeploy can deploy it?
Robert
