SPARKFUN 9DOF IMU STICK ACCELEROMETER AND GYRO RAW DATA TO WPF VIA MQTT
So, still learning, but I seem to be getting along ok, solving a few problems I see others encountering - so if the code helps anyone, great.
If nothing else it shows off WPF simplicity a little for those of you unfamiliar with with it. WPF was the intended replacement for UI on windows. It has been made 'legacy' at this point, but the follow-up - WIndows Store apps are very similar.
direct links;
http://www.spiked3.c...2014/06/imu.zip
The video shows some 'unaligned' response. I assure you this was a video alignment problem. In actuality the response is very fast and aligned. Next time I will do the screen capture differently as I think frame rate differences messed with me.
