i am trying to get temperature using LM75, this sensor has I2C interface.
But its not working, i have atached code, this code i found somewhere on internet like working code.
Another example how to get temperature from sensor i didnt get.
Please, can anybody help me ?
using System.Net;
using System.Net.Sockets;
namespace LM75_Tutorial
const byte DeviceId = 0x49; //address
const byte ClockRateKHz = 59; //kHz
const int transactionTimeout = 1000; //1 sec.
const byte halfMask = 0x80; //0.5 st.C, 0b10000000
I2CDevice device = null;
try
device = new I2CDevice(
new I2CDevice.Configuration(DeviceId, ClockRateKHz));
byte[] writeBuffer = { 0x00 };
byte[] readBuffer = new byte[2];
I2CDevice.I2CTransaction[] action = new I2CDevice.I2CTransaction[]
I2CDevice.CreateWriteTransaction(writeBuffer)
, I2CDevice.CreateReadTransaction(readBuffer)
if (device.Execute(action, transactionTimeout) == 3)
float temperature = readBuffer[0] +
(((readBuffer[1] & halfMask) != 0) ? 0.5f : 0f);
Debug.Print(temperature.ToString());
else
Debug.Print("LM75 is not responding...");
catch (Exception ex)
Debug.Print(ex.Message);
finally
device.Dispose();
Thread.Sleep(1000);
knowing nothing about your device...your code looks ok. So, I'll ask the question that's always asked: do you have pull-up resistors connected to the SDA and SCL lines?
Can you describe what is happening? ...are you seeing "LM75 is not responding..." printed out, or are you getting an exception thrown, or is the temperature reading not right? As gismo said verify pull-up resistors and also check the address of the device (is A0 pulled HIGH, and A1, A2 pulled LOW?).
I am not using any pull-up resistors, i am using ND2+
On The same ND2+ is working LCD with I2C interface...without pullup resistor.
In which case is important to use pull up resistor ?
I have used all address combination
A0, A1 and A2 are not soldered, so i think the address if 49, but i have tried last address 4F, because i wasnt sure..so it must be the last or first address.
1001000 = 40
1001111 = 4F
But in the debug is displayed ....LM75 is not responding...
I bet that LCD has pull-ups built into it. With a volt meter, check voltage of SDA and SCL. If they are high, pullups are built in.
All I2C needs a pull-up on the bus. If so, just connect the LM75 to the same bus as the LCD at the same time. OR just connect the LM47 with pull-up resistors. 4.7kOhm to start.
Ah, I believe that is your problem. See page 4 of the datasheet...
It states that the address pins A0, A1, and A2 should "not be left unconnected". Tie them all to ground and set the address of the device to be 0x48. Hopefully that will work for you.
As far as the pull-ups go, you are probably fine if the pull-up resistors exist somewhere on the bus...i.e. on the LCD module. Especially since the I2C bus is working for the LCD.
Keep us posted.
oh i see that for now...Do not leave unconnected....i will check it...then i give back feedback
